C3 Shortened Composite
Does anybody know off hand if VBP offers a shortened rear mono spring?
I want to make sure I can fitting the largest rim/tire combo when its time.
read this thread sounds like it had to be custom ordered
https://www.corvetteforum.com/forums...e-vbp-one.html
I ordered mine 1" narrower, .5" off each side.
Running 285/45/18's with plenty of clearance.
I don't recall the extra charge but I think it was pretty minor. Maybe $30.
Yes, you can get a shortened composite spring from VBP, all you have to do is ask. Both my 68 and 70 cars have VBP composite springs with 1/2 inch shortened from each end. Best I remember, VBP doesn't charge extra to shorten them.
The shortened spring gives you the option of running a little wider tire.
If you buy offset trailing arms, you need (IMO) to order the shorter spring to allow you to effectively take advantage of the offset trailing arm's wider tire provision.
BTW: The composite springs are sooooo much easier to install than the stock multi-leaf steel spring.
worship79 (11-10-2016)
Stock trailing arms? If so, parking brake bracket still in original spot? Any tire rub on the frame or body? Thanks... considering the same!
