1974 Rear suspension suggestions?
I have a 1974 Corvette Stingray L-48 Coupe that I'm starting to restore. I noticed that while I was at the rear of the car, taking the corroded gas tank out, the leaf spring seemed very worn out/ saggy. I've looked on Ecklers and saw the original 9-leaf, the 7-leaf gymkhana, and some single leaf springs that are more expensive. I was wondering which leaf spring I should get. I have no idea what the differences between the gymkhana, the original, and the single leaf springs are other than the amount of leaves. Difference in handling? Which one would be best? Also is there a specific way to remove and install the leaf spring?
r
JMO If you are restoring the car I would replace with like spring,9 leaf with a 9 leaf. The others tend to add cash and complexity. Spend your money on replacing all the front and rear suspension parts.
Looking at your picture of the rear end, "you have a long row to hoe" mister potato.
I'd bet your diff will need rebuilding also. With those half shafts running practically horizontal like they are, they are pushing the yokes into the diff causing massive wear on the ends of the yoke. After removing the half shafts, see if the the yokes have any movement in and out.
Check out Vette Brakes & Products website video section... you'll find video clips which include a rear suspension sample that discusses removing that rear leaf spring.
I forgot to mention that the spring bolts are rusted and require care to remove!
Use something like power blaster before you try to remove them, many a differential cases have broken mounting holes. Use a thread chaser not a thread tap to clean the bolt holes.
Looks like the typical ...long ignored corvette suspensions .
Prepare for a major attack on your check book
You said that your car is a '74 but you have a diff cover off a '78-79 and a matching leaf spring so when you go to buy replacement parts you'll have to order a spring for a 78-79. You can tell which year cover it is by the steps in the spring mount face where the bolts thread into the cover. The 63-77 covers are flat across the back where those bolts are and the bolts are 9/16" in diameter. The early springs are 2.25" wide and the 78-79's are 2.5" wide. 78-79's also use 7/16 bolts to attach the spring to the cover.
