Is it unsafe to drive a C3 with no shims in rear trailing arms?
I just rebuilt the rear suspension on my C3 and replaced the trailing arms with offset aftermarket ones from VanSteel. All the old rusty shims were removed from the front mounting point of the arms. I want to take it in for an alignment and have them replace the shims with new ones. Is it OK to drive it a couple miles this way, slowly?
Received 1,244 Likes
Unsafe? Only if you don't video it.
Your alignment shop will not have the shims, you have to buy them from a vendor.
Install the shims first then drive to the shop.
The rear may do a little walking around, but if it's a few miles and low speed it should be do-able, I don't think the sky will fall. Better to just jam them in on both sides of the arms as many as you can, at least the alignment won't be changing around as you drive.
It's not going to be a death ride like everyone else thinks.
FYI, the shims set the rear toe, and a little toe-in is preferred! I would search around the forum for more current alignment specs, both front and rear, and especially for radial tires.
Hope the shop knows how to do a C3....
bashcraft and toobroke are on the money. Drove mine to the alignment shop 5 miles away with no shims, no problem. All you get is some weird 'jinking' as you turn. Nice and easy and you're fine.
Make sure you have the 'slotted' shims to make life easy for your installer otherwise he will cuss and moan a little.
