Correct Hood for a Big Block
Old 06-29-2015, 12:39 PM
Dhasso
Dhasso's Avatar
Default Correct Hood for a Big Block
Hello All,
I am putting a 454 motor into my 1970 corvette. It had a 350 with a Edelbrock performer intake and holley carb. Will the big block with the same intake and carb fit under the stock hood? I would be putting on a stock big block/LT-1 hood. I do not want to go to an L88 type hood. Does anyone have any experience?
Thank you in advance,
Dhasso
Old 06-29-2015, 03:10 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
you would need a drop base air cleaner. You would also need a short filter element which defeats the purpose of increased airflow.
Old 06-29-2015, 03:29 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
almost any BB intake other than stock height, steel or Aluminum
will require some minor modifications to fit under stock BB hood.
Old 06-29-2015, 03:37 PM
ddawson
ddawson's Avatar
To fit I used a LS6 BBC intake and Quick Fuel carburetor.
This allows the shield and spacer to be used and I still had a little more room.
Old 06-29-2015, 04:25 PM
Phalanx_vette
Phalanx_vette's Avatar
The performer and holley should clear with a low profile air filter.
I had an edelbrock 1407 on the stock intake with a 1/2" spacer, and low filter, but I squished the filter slightly with the hood closed. There isn't much room, even with the BB hoods. That 1/2" spacer was the difference from clearing and not in mine.
I don't know where you're located, but I am selling my LT-1 style hood in favor of an L-88 wiper delete.
If you're interested PM me.
Old 07-01-2015, 01:11 PM
scrappy76
scrappy76's Avatar
My experience is as follows :
I installed a 454 with a stock intake and qjet in my 76. It fir under the hood just barely using one of the triangle mesh air cleaner. Then I installed an ecklers low rise hood ( about 2" above stock ), and was able to install a regular 14 x 3 air cleaner. I then installed an edelbrock performer intake. I was not able shut the hood untill I installed a drop base on the 14" air cleaner. Right now there is only about 1/8" between the round head bolt holding the air cleaner down and the hood.
I am hoping that when I install my L88 hood I just bought, I can go back to the regular base for the air cleaner. The edelbrock performer is a pretty high manifold compared to stock.
Old 07-01-2015, 05:12 PM
69Vett
69Vett's Avatar
I am using stock Alum. intake and Holley,
I made my own custom dropped base air cleaner.
everything fits nicely under a BB hood.
Old 07-01-2015, 05:15 PM
GregS_72
GregS_72's Avatar
Location: St Louis MO http://1972corvetterestomod.blogspot.com/
Have you had a chance to check the fit of that L88 hood? Any body work needed to get it to fit properly? Where did you get the hood? Thanks!
To Correct Hood for a Big Block
Quick Reply: Correct Hood for a Big Block
