putting steering gear on center on car
Steering box input shaft has a flat. Steering column has a flat ground on it. All Flats face up, to center steering box and column.
Don't forget the two marks on the steering wheel end of the steering column to index the direction indicators. The two punch marks should be together at 12 o'clock when the flats 69vett mentioned are facing up.
Now if needed the tie rods can be set for straight ahead and toe-in!
The area where the box is , combined with my engine combo makes it difficult to see if the flat is really at 12 o'clock. I set it like that, and the steering wheel straight up, but when letting go of the steering the wheel is slightly offset to the right.
Would like a method a little more exact than that.
Okay, so if you wind one tie rod adjustment in and the other out exactly the same amount you should be able to get the wheels pointing straight ahead also.
Have you read this?
Revised: 28JL2009
STEERING WHEEL & STEERING SYSTEM CENTERING PROCEDURE
(CORVETTE 1963-82, CAMARO/FIREBIRD 1967-69, AND NOVA, SKYLARK,
VENTURA, APOLLO 1968-74, & OTHER GM REAR STEER VEHICLES)
Have you read this?
Revised: 28JL2009
