AC belt rubs radiator hose help
Old 07-04-2015, 10:30 PM
allena
allena's Avatar
Default AC belt rubs radiator hose help
Greetings
I have a 75 vette with AC and I've noticed a little spot on my radiator hose
where the ac belt rubs some on the hose, it's not touching when the engine
is off though. it must occur sometimes.
Is there some kind of shield I could install for this?
Where can I buy it?
Thanx in advance
A
Old 07-05-2015, 05:03 PM
Blue73Shark
Blue73Shark's Avatar
Had this happen when I put on a new lower radiator hose on my 73; belt cut a small groove in it. I did this:
1) tighten AC belt. Make sure it does not flop and hit the belt
2) move the hose slightly away from the engine block. This will keep the bend in the hose further away from the belt
Fran
Old 07-05-2015, 05:11 PM
doctorgene
doctorgene's Avatar
Yes Sir; On the 1980 model there is a brace that runs down to the lower front of the block that has a shield on it from the factory. I don't know if it will work on your year or not. So if the factory didn't know about this problem in 1973, they did become aware of it in the latter years. Maybe some one will tell you if this shield was present, or if it will work. Have a great one. Gene
Old 07-06-2015, 09:58 AM
calif phil
calif phil's Avatar
Originally Posted by allena
Greetings
Where can I buy it?
Thanx in advance
A
Many years ago my belt was rubbing on my '73 and I noticed that the later models came with a metal guard. I went to the Chevy dealer and ordered one. It was cheap and works great. I was thinking a 1979 was what I asked them to look up the guard part number. It's been 30 years ago but I do know the part bolted right on and works great.
To AC belt rubs radiator hose help
Quick Reply: AC belt rubs radiator hose help
