how much power does the 82 fan with clutch suck up, should i switch?
Old 07-10-2015, 10:44 AM
slickfx3
slickfx3's Avatar
Default how much power does the 82 fan with clutch suck up, should i switch?
to electric or a flex fan?
Old 07-10-2015, 11:04 AM
bashcraft
bashcraft's Avatar
The clutch fan won't use any more power that the alternator will use to drive the electric fan.
Old 07-10-2015, 11:15 AM
worship79
Support Corvetteforum!
worship79's Avatar
The clutch type only engages when too hot, so that's pretty efficient. I replaced my because it needed replacement and went electric just for the fun of it.
Old 07-10-2015, 11:53 AM
gungatim
gungatim's Avatar
flex fans have generally been shown to be much less effective than stock clutch fans, from the articles I have read anyway...
switching to electric has it's benefits, but you're still going to be converting mechanical energy into electric, so you're only ahead if/when the fan is turned off, which will be rare when it's running.
Old 07-10-2015, 01:06 PM
SI67
SI67's Avatar
My understanding is that for an engine that's pretty much stock, a properly operating clutch fan is excellent for effective cooling and efficiency, but I do have a question about your comment:
If the ON/OFF temperature (assuming it's controlled by a thermostatic switch) is appropriate, wouldn't the fan motor generally be OFF at highway speeds?
Steve
Old 07-10-2015, 01:11 PM
bashcraft
bashcraft's Avatar
Steve
Yeah, and the clutch fan will also be free wheeling.
mikem350
mikem350's Avatar
Steve
Generally yes. BUT my car runs a little cooler with AC on with the fan on (via a manual switch). Also all the radiator seals are needed, especially the one at the top of core support to "ram" all the air through the radiator!
Old 07-10-2015, 02:00 PM
Easy Mike
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
...how much power does the 82 fan with clutch suckup...
Next to nothing.
...should i switch to electric...
Your 82 came with a factory electric auxiliary fan. All 82s had them.
gungatim
gungatim's Avatar
Steve
yes, it SHOULD be, if there is enough air moving through and all seals etc. are intact, but nobody drives at highway speeds all the time, you start the car, idle, stop at light, drive to the dairy queen, stop to pickup a hitchhiker, etc... highway speed is not where you need power anyway, it's getting up to speed or racing around town
alternatively people just use an on/off switch, I've even seen some always on with ignition...not how I'd do it but it happens...if you were planning to race and needed that last little bit of power, you might turn the fan off while doing a run then back on when it's done maybe...
Old 07-10-2015, 05:46 PM
Torqued Off
Torqued Off's Avatar
Received 2,657 Likes on 1,398 Posts
Silliness...it is not measurable unless you are racing.
Old 07-10-2015, 10:21 PM
Unforgiven1
Unforgiven1's Avatar
My opinion: Yes, electric fan. The mechanical fan uses horsepower, adds mechanical complexity, and induces stress on the water pump. Pull that enormous fan shroud off while you're at it and save some weight/add room.
Old 07-10-2015, 10:28 PM
Torqued Off
Default Disagree
How much real HP do you think it uses, and could anyone tell the difference.
Add ELECTRICAL complexity, which includes if electrical fans, wiring or power fails you are done, as opposed to a fan mechanicially connected to the engine...if engine runs, fan will run.
Weight...again, does it really make a difference.
I know its fun to make performance improvements, but unless you are really racing the car, its all just a waste of money....BUT, we own our cars, and we can do anything we can afford to to. Many people believe that lots of mods are trying to fix things that are really not broke. Chevy 350's have been built by the hundreds of thousands, with mechanical fans, hardly see why we need to outsmart that.
Old 07-10-2015, 10:50 PM
Unforgiven1
I'm just a fan (no pun intended) of technology, especially where engine management is concerned but also with regards to cooling systems. I run a 94 Camaro/Firebird radiator with electric fans in my 1980 with none of the foam around the core support and I've never had a problem keeping it cool. I've deleted mechanical fans on Chevy Trucks, Astro vans, Jeeps of all types, Chevelles, Cutlasses, and probably a few I've forgotten. I don't miss the roar on start up or worrying about tangling with the damn thing while working under the hood with the engine running.
Besides, when are you driving a Corvette and not racing?
Old 07-11-2015, 11:52 AM
AboveTheLogic
AboveTheLogic's Avatar
Not having that huge and annoying shroud in the way is definitely a benefit. When I bought my C3 a couple of years ago the shroud was missing. Used shrouds in mediocre condition on ebay had bigger price tags than the electric setup I have with a fan shroud that I made out of a large baking sheet. Looks better, easier to get to things, no regrets.
Old 07-11-2015, 12:54 PM
lionelhutz
lionelhutz's Avatar
Finding decent back to back test data is difficult but here are a couple of links to check out,
http://www.carnut.com/ramblin/dyno.html
http://www.network54.com/Forum/21565...+Fan+Dyno+Test
To switch, you also have to make sure your charging system is capable and you have to implement a proper control scheme. For dual fans I like the 3-relay series/parallel wiring and 2 levels of temperature switch. For AC, there is a pressure switch that can turn the fans on when the AC needs the fans.
This is false once you count the rpm range the engine operates in. It's rather difficult to make a mechanical fan operate efficiently over the whole rpm range an engine operates in. An electric fan can be optimized to move the proper amount of air at it's fixed operating speed.
The fan in my 65 Impala draws about 20A. At 14V this is 280W. Even assuming a terrible 50% efficiency for the alternator and belt drive this is a 560W or 0.75hp load when it is running. When it is not running it a 0hp load. It cycles on and off at around a 50% duty cycle even when I'm stuck in traffic on a hot day. I highly doubt any mechanical fan could beat that for efficiency.
Old 07-11-2015, 02:29 PM
74modified
74modified's Avatar
I use both on - different vehicles. There a pros & cons for both.
On my 74 I am using a two speed single electric.
My take on electric:
First you need an electrical system that can handle the load.
I don’t like cheap aftermarket fans. I like OEM fans, but have never used a high quality aftermarket fan - I am too cheap.
You still need to have some sort of shroud to force the air to come through the rad.
I like that with an electric, I can have full airflow at low speed, regardless of engine RPM.
Old 07-11-2015, 03:17 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Only drawback to an electric is if theres a failure youre stuck, mech fans rarely if every fail
Stock clutch fans work well but not a fan of the weight off the water pump nose.
If it were me id get a nylon flex fan (they are black weigh a few ozs arent real noisy and are cheap-call Summit), if you want get an aux electric that would come on at xxx temp maybe even with a manual switch?! (prob not needed though)
You may need a short spacer, some bolts....ran those on my cars for yrs and loved them. Never broke and kept it cool. When I get the time Im putting mine back on with the electric as an aux for the track to cool down in between runs. Do not like the constant temp cycling the electric fans bring on
Wouldnt come anywhere near one of those metal flex fans had a few of those go bad....one cracked my hood, the other broke loose a blade at idle when I had my head under the hood, real close call. Heard a racket and a big bang couldnt see anything happened so fast.
To how much power does the 82 fan with clutch suck up, should i switch?
Old 07-11-2015, 08:08 PM
diehrd
diehrd's Avatar
For anyone to say a fan does not pull HP out of a motor please rethink that. It is quite a bit of work to push those blades through the air. If I remember right from things I have read it is about 12hp .
Now that is not a lot of hp but for many reasons be it economical hp gains or a racer looking for every spare pony it is a good idea to go electric
Old 07-11-2015, 08:33 PM
AirBusPilot
AirBusPilot's Avatar
There is a reason why nearly OEM has switched to electric fans.
Old 07-11-2015, 08:35 PM
AirBusPilot
True. And electric fans don't usually turn on until the engine reaches a temp above normal operating temp. So there is zero drag until that point, unlike even a disengaged mechanical fan.
Quick Reply: how much power does the 82 fan with clutch suck up, should i switch?
