Heat soak to the Carb
#41
Nam Labrat
Received 4,176 Likes
No test drive yet....I started the car today.....found one fuel leak---tightened the fitting and checked/re-set the timing now that the distributor is working correctly.
The regulator was set for max pressure/9psi which caused the car to run as though the choke had closed (the air plenum was removed...the choke was fully opened).
I adjusted the pressure down slowly and midway the engine idled smoothly.
It starts well now in about two engine revolutions cold or hot.....no more constant cranking with the accelerator to the floor.
There is visible fuel return to the tank....all is well.
I will make any future posts in my build thread.
#42
#43
Nam Labrat
Would you have any idea why the engine was surging slightly up and down 50 RPM.....could it have been because I didn't re-adjust the idle air screws after I made the modification?
The regulator will only go down to 4.5 psi.....I'll adjust it down tomorrow before the test drive.
Thanks.
Thanks.
#44
Thanks.
Thanks.
There are other things. Guys will chime in.
#45
Received 1,246 Likes
Thanks.
Thanks.
Got any timing numbers that you could post?
#46
Nam Labrat
I'll see tomorrow/Thanks.
14* base timing/vacuum advance hose plugged.
Add 14* for mechanical advance at 3000 rpm = 28*.
Add 14* (full advance with manifold vacuum) to the 28 = 42*
It quit surging after I adjusted the idle air screws
#47
It's steady/no movement........but I forgot to notice if it "jumps" when the rpm is bumped up a couple hundred.
I just checked today:
Blip the throttle at 3000, and see if your all in or not.
#49
Is anyone else amazed that his hood will close with that setup?
I have a tiny air filter until I can find a good drop base just because there is NO ROOM under the hood and adding my spacer under the carb did not help the situation.
I will say that the car is much easier to start now. However, I notice that fuel will slowly drain out of my filter too (day or two and it will be dry). Guess I need to get on with my plans of replacing the fuel pump. After all, I purchased it already and it's just sitting there waiting for me to install it. This was just the motivation I needed. Thanks DG!
#50
Nam Labrat
Naaaaaaaaaa! Too much trouble....... Bolt on the new pump!
