1974 power steering ram rebuild
I'm reasonably good at rebuilding things, provided that I can get the repair parts.
So I'm wondering, where is a source for the best quality rebuild parts for the power steering ram on my '74.
The next question is, has anyone converted to a steering gear with the hydraulics built in?
Or is suggesting such a thing considered blasphemy?
It only takes about 30 minutes to put a new rod seal in and the seal kit costs about $15 if I recall. And the kits are readily available.
If the cylinder is functioning OK, then the only thing to change is the outboard seal set. As mentioned, that replacement seal set is inexpensive and doesn't take much time to do. You do have to be careful not to damage the ram surface when you dig the old seal out. Note the order of the removed seal pieces, so you can rebuild it properly (if there is no good set of instructions with the seal kit).
If you find the ram to be bent or have excessive wear on the surface (light surface 'frosting' is fine and not abnormal), that could be causing leaking and would require ram cylinder to be replaced. It's a sealed unit, so internal repairs can't be made.
Just did this job myself along with control valve rebuild. Lots of good suppliers and help videos. The Ram can only have the end seal replaced as it is a welded unit.
Parts:
Wilcox
https://willcoxcorvette.com/parts?cat=205
or
Corvette Stainless Steel Brakes
http://www.cssbinc.com/c3powersteering.aspx
and just all others Zips, Paragon....etc
Repair Videos and docs
http://www.cssbinc.com/howto.aspx
Just to name a few
John
Parts:
Wilcox
or
Just to name a few
John
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Before you try to rebuild the cylinder take a hard look at the rod. The rod is chrome plated and if you look right in the middle and see a wear groove through the chrome I wouldn't waste my time or money trying to fix it.
Over time the rod will wear "On Center" and create a dip (or groove) in the rod, when this is present the constant in and out movement will just wear out the new seal.
If you look at this picture you'll see what I'm talking about. Look between the 6 1/4 to 6 5/8" marks on the tape and you'll see it. You'll be able to feel it with your finger too. If you cylinder is in this shape then I would go with a new one.
If you don't have this on your rod then by all means the rebuild is pretty easy.
Willcox
Willcox
I installed the Borgeson steering gear and now I have spare parts left over, namely a ram and control valve set from the '74 and another set from my '75 parts car.
If anyone wants either, just let me know. You can have them for the price of shipping and maybe a few $$ for my troubles packing them.
