why this relay
Received 1,468 Likes
Cruise-In II Veteran
...why this relay...
why this relay
Well I jumped it as shown and still have no crank with clutch pushed in, sitting in seat with seat belt fastened. I know it's an electrical issue somewhere because the blower motor runs with the key off...
why this relay
It seems something is grounding out somewhere, there's almost 2 volts
At the coil with the key off, good thing I have a disconnect switch, maybe it was done when I dropped the steering column to put a new rag joint on.
Further investigation will happen....
