Beginning the journey
Cruising
I'm new so I'll say hello before I start with the questions I'm new to vettes like I was given a 75 l82 stingray Friday I'm looking to go the resto mod way more than genuine numbers resto I want to have the look of old school and the drive of built screaming 350 going to mate a newer 6 speed manual tranny first thing I need to know is I'm 6'1" 300 lbs and the steering wheel digs into my thighs so I have to do either steering column swap or custom fabricate something my ears are open look forward to hearing what yall have to say and I will try to get pics of on here soon thanks in advance
The steering column may not be bolted up completely. In 6'4 260lbs and I have plenty of room. I would check the bolts first that might save you time and money. You may have tilt steering which would cause your tight situation. If you have two levers on the passages side of column you may be able to adjust to fit your situation.
I gather you live in China? Your car is upside down. If your steering column has two levers sticking out of the left side the front one is for adjusting the amount of tilt in your steering wheel. If it doesn't have the additional front (shorter) lever you could consider buying a 1" or 2" smaller diameter steering wheel to give you more leg room.
It won't be cheap--you'll soon discover that nothing about a C-3 is cheap--but I do suggest keeping an eye out for a tilt and telescope steering column. Given the seating position the T&T was an EXTREMELY popular option.
BTW, I'm 6'4, 280# and fit nicely in my '79 even if onlookers seem amazed with the ease I enter and exit.
[QUOTE=SwampeastMike;1590191801]It won't be cheap--you'll soon discover that nothing about a C-3 is cheap--
Sometimes free is too much $
Nam Labrat
Received 4,178 Likes
Welcome to the Forum!
If you have power steering, a 2 inch smaller steering wheel would gain an inch of extra clearance (do not go smaller than 13" in diameter, though).........
since you will resto-mod the car, you could modify the steering column mounting brackets to gain another inch.......
you could also remove the seat sliders/adjuster to lower the driver's seat down to the floorboard and gain another half-inch/maybe a little more.
There........2 1/2 inches of extra room....
Keep us updated in this same thread/makes it easier to find!
(Ask a Forum Administrator to move your entire thread to the "General Forum".....that is where restoration/Build threads are located)
Cruising
