I have this ticking noise...
Yes, its another one of those threads...
I just cant figure out where this noise is coming from. I built this engine this winter, and in the spring it ran quiet and good.
Mid summer I installed the supercharger, after changing the cylinder head gaskets, and assembled it all together again. Then the ticking started. Its not the rockers. You can hear them in the video below, but the ticking noise Im talking about, or more like a clacking noise you can hear beside the noise from the rockers. It sounds like a diesel, and it does not go away when the car gets hot, and it follows the RPM of the car.
I have a Hydraulic flat tapped camshaft and roller rockers as you can see.
Video of the noise at startup (warm engine):
Anyone got any ideas?
have you tried a stethoscope or just a piece of rubber hose to narrow down the source of the noise?
Its not the fuel pump atleast, there I couldnt hear ****.
Btw. I was checking the roller rockers with the covers off today to see if it was them, which it was not. During the 5 minutes it took to do this, I didnt see about any oil fill up in the heads. The holes which leads the oil down again is at the top of them, so there has to be some flooding before it flows down. Isnt that a bit strange during 5 minute?
Also, I know it flows oil to the top. I attended a drag race on saturday, and on full RPM it spewed oil through the gasket of the valve cover at the right side. So it would have had a lot of pressure and oil in the heads. Can this excessive noise be because of a clog or bad oil pump?
I would be checking the oil pressure. Seems a bit odd that you did not witness more oil flow from the rockers in the span of 5 minutes. Is the gauge electric or actual? Is it accurate? If that check out maybe flow is impeded somehow. oil pickup loose, oil pump problem etc. Must have some if you are able to drag it and not seize anything.
My drain back holes are at the bottom of the head, not the top. Seems that arrangement may encourage leakage from the valve cover.
I chased a ticking noise around for a long time. What I ended up doing was open the hood and start the engine after dark. What I found was one or two arcs coming from bad plug wires. Not enough yet to show up in the performance, but enough to make a ticking noise. Just a thought to do the simple stuff first. You might luck out. Good luck.
Sounds like valve lash so to be sure it is or is not..............
I would adjust the valves one by one and with it running .. Back off till one clatters , slowly tighten till it stops and add cam makers suggested lash setting. Do all that way on both sides ..
OR as I am sure someone will chime in dont adjust while it is running,, do it this way
Get #1 to Top Dead Center
loosen one at a time until you feel push rod and rocker arm have separation , SLOWLY snug nut until arm and push rod have no slack between them and then add cam makers suggested pre load turn
Exh.- 1 – 3 – 4 -8
Int.- 1- 2 – 5 - 7
Get #6 to Top Dead Center
Exh.- 2 – 5 – 6 – 7
Int.- 3 – 4- 6 - 8
Exh.- 1 – 3 – 4 -8
Int.- 1- 2 – 5 - 7
Exh.- 2 – 5 – 6 – 7
Int.- 3 – 4- 6 - 8
Thanks for all the replies so far.
Its not leakage at the header gaskets as I changed these and there were no traces of exhaust anywhere.
I've also adjusted my valves while the engine is running without any significant change.
I also started the engine with the belt to the supercharger disconnected, and the sound was still there.
From what I can hear its not the valves, as the sound is much for distinct than valve ticking, its more of a deep clacking sound, that of a diesel engine.
I am however going to have a deeper look at the inside of my engine when I store the car for the winter in a few months, by ordering a new crankshaft, pistons and rods. At this point Ill check the oil pump for any flaws aswell.
The gear box is a 4 speed manual M21, so its not a converter making the sound, but I can exclude the fact that the sound is coming from the back of the engine / front of the transmission either.
