Turn signal switch replacement difficulty?
Old 08-24-2015, 09:50 PM
medic1555
medic1555's Avatar
Default Turn signal switch replacement difficulty?
How difficult is it to change out the turn signal switch on a '79 with T&T column? Mine has lost its ability to return to the off center position and the lever fell off today. The deepest I've ever been in the column was to repair the horn.
Old 08-24-2015, 10:03 PM
toobroketoretire
toobroketoretire's Avatar
Its an easy job.
Old 08-25-2015, 12:09 AM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1969-1982 Corvette Turn Signal Switch Installation
Old 08-25-2015, 12:21 PM
medic1555
medic1555's Avatar
Originally Posted by Willcox Corvette
WOW! That's a great write up, thank you very much! As I'm reading this I'm wondering how an engineers mind must work to ever design such a beast. One would think there would be a more simple solution even back then. Thanks again!
Old 08-25-2015, 12:46 PM
0Willcox Corvette
Former Vendor
It's really not all that hard. We always un-pin the lower connector and always use the old harness to pull the new through. Take your time and you'll get it.
Willcox
Old 08-25-2015, 09:49 PM
medic1555
medic1555's Avatar
Willcox
Thank you sooo much. Your contribution to this community is priceless (in my opinion). I will be ordering the switch from you guys.
Old 08-25-2015, 10:32 PM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
There is a slight oversight in the video with respect to the early locking C3 steering columns as compared to the later ones.. The 1977 through 1982 T&T steering column is somewhat different than the 1969 through 1976 T&T steering column. The early columns (as shown in the video) had a completely round head. The later columns (and your 1979) had a square bulge on the left hand side of the column head. These later columns had a dimmer pivot switch that was actuated by the turn signal lever.
T&T columns with a bulge are different from the earlier columns (as shown in the video). They are different as follows:
Early - Turn signal lever has a male thread and screws into the turn signal switch.
Late - Turn signal lever plugs into the dimmer pivot assembly. This design requires a cross-over arm from the dimmer pivot to attach to the turn signal switch. The fact that your lever "fell off" means that you may require a dimmer pivot as well as a new turn signal lever.
Unfortunately, the dimmer pivot is not addressed in the video.
Jim
To Turn signal switch replacement difficulty?
Quick Reply: Turn signal switch replacement difficulty?
