Vacuum Connections
Old 08-25-2015, 12:16 PM
haarvik
haarvik's Avatar
Default Vacuum Connections
I think I may have found my problem with my loping, but just want to make sure. Right now my PCV valve is connected to the back of the intake manifold, and my brake booster is connected to the large port on the Holley 4160. Isn't this backwards? Shouldn't the PCV valve be connected to the large port on the carb?
Old 08-25-2015, 02:59 PM
toobroketoretire
toobroketoretire's Avatar
It doesn't matter.
Old 08-25-2015, 04:20 PM
Strokemyaxe
Strokemyaxe's Avatar
Originally Posted by toobroketoretire
It doesn't matter.
Well my brake booster is connected to the large port at rear of carb and PCV is connected to a port on front. I believe they are both manifold vacuum sources.
Old 08-25-2015, 04:32 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
typical configuration Booster in the back by itself.
PCV connected to the front by itself.
good luck.
To Vacuum Connections
Quick Reply: Vacuum Connections
