Quadrajet Trouble
The subject of commercially rebuilt Q-jets has been discussed on this forum too many times to count, and it has been determined that these carbs are not reliable after being commercially rebuilt.
The best way to get a reliable Q-Jet is to find a unit that has not been thru a commercial rebuilding process and rebuild that. There are still many candidates out there, eBay usually has several. It does take a trained eye to determine if it has not been commercially rebuilt.
If you are not up to the task of rebuilding one yourself, you could find someone to do it. Lars would be my first choice, although I haven't seen him posting on the forum in a while. I had read someone mentioned that he may not be rebuilding carbs right now. Other names are Ole's carb, Sean Murphy, or Cliff Ruggles.
There is also the option of changing to a Holley spread bore if you didn't want to deal with the rebuild process, as these are still available new.
I don't know what a wide band 02 monitor is. The carbs are guaranteed so they send me a new one. Yes, the engine is a stock '69 350, except the recently added edelbrock intake.
Yes, I know about the warpage, not the case. Using a Carter electric fuel pump with a new fuel regulator set at 3.5 psi (gauge verified).
I can cover the air horn with my hand shutting off the air, no change in engine speed so I assume it's running very rich.
http://www.cliffshighperformance.com/
If you can wind the idle screws in or cover it with your hand and it doesn't kill the engine then you have issues.
Why not just clean up your old carb and try it?
2023 Restomod of the Year Finalist
I bought a carb from ebay a couple of months ago. Tried to rebuild it but it had a frozen power piston and I couldn't free it up without destroying it, so I removed the base plate that had good idle screws and put it on my old quad. Still has issues but may be better to work thru these than mess around with this commercial rebuild.
I like quadrajets, obviously, when they run right. Can't understand why I can't get at least one of these to work. If this doesn't happen, however, then it's Holley time!
BTW, Lars doesn't do rebuilds anymore as of June 1. Guess he's actively retired. Good man, wish him luck.
You guys are right, that should shut down the engine. Gotta be it, but don't know where. Did the propane leak check, may do it again. Is there such a thing as a bad intake, cracked, etc? This one is new. I would think you could hear or see that.
When you said you could cover the carb with your hand and it would make no difference I assumed you meant partially cover the carb?
Remove all the grease and oil from the carb body, then soak it in Rust Evaporator (or equivalent ) for a few days, and the power piston will free-up. I've done a couple that way.
Maybe I missed something, but the intake was changed at the same time, right? Perhaps you have a leak from the intake manifold. I have seen them leak on both the outside and from the valley.
I've checked the outside, but not the inside. I'll check that next. Should be a slight vacuum when removing the oil fill cap, right?
In theory, there may be a slight vacuum because of the PCV. However, normal wear will allow blow-by creating a positive pressure in the crankcase that the PCV can't overcome. So... it may or may not have vacuum in the case, but if it were me I would check and see by removing the oil dipstick, it might be easier to tell because of the smaller opening.
You could check the spark plugs and see if any are oily.
I am rambling...
#33
I hate the thought of removing that intake again, but I think everyone has agreed there is a vacuum leak, probably internal but I will recheck. I used good gaskets so my first thought is there must be an anglular mismatch between the intake and the heads, although i don't see how. This is a stock '69 engine that hasn't been apart, and the intake is a new performer 2101.
I'll do a clay ball check dry & see what I find. Is this mismatch common? How else can an internal leak happen?
#34
Make sure that the mounting ears on the manifold are not contacting the heads and preventing the manifold from seating. Did you allow the sealant on the end gaskets to harden before setting the manifold. They can shift and cause a leak.
#35
#36
jet performance carb should have an adjustable ATP for the power valve, should be a allen plug at top front of the carb, should be a screw head under it for the ATP.
i would also check to make sure you have the correct base gasket on the carb to intake.
#38
I'm using a '73 quad that doesn't have ATP. Impression I see on the base gasket appears to be sealing well.
#39
Do you have an EGR valve that may be stuck open?
Have you pulled and capped ALL vacuum lines to see if something is leaking?
#40
Away from home this weekend but thinking about my possible vacuum leak and have a question.
Can you still have a vacuum leak bad enough to cause all my problems but still pull 20" on the gauge at idle?
