Help with setting dwell on dual points
Received 1,244 Likes
Large gap = small dwell
Small gap= large dwell.
Who made your distributor?
They can tell you what the dwell is.
Dwell angle is the time the points are closed.
The single point time makes 30* of dwell, with two sets of points the dwell time will be higher.
Old Accel 371000 A. I believe Big2Bird is correct. I should have set them each around 26, but for some reason I was thinking it was 29.
