Differential Lube
Differential Lube
If I need to top off my differential lube, what lube do you guys recommend. I'm not getting it from on-line vendor, I'll run to my local parts house. I have no clue what brand I have in there now, so can mix one with the other... As long as its for a posi-rear???
Cruise-In IX Veteran
I personally went with Tom's choice of Lucas 75w140 gear oil. I found it at the local autozone. The diff took about 1.5-2 quarts.
I went with whatever name brand the local parts store had in stock and added the appropriate amount on GM additive.
It may not make any difference but I drained the diff, refilled and drove around until it was hot then drained it again in hopes of thoroughly flushing the diff.
