72 rear spring diff bolts
the 4 bolts tha hold the rear spring to the diff, what grade should they be?
the ones i removed were 3 dash meaning grade 5,
but reading on net people say use grade 8...
i'm confused....
as i'm putting a new spring on to replace my saggy one, the bolts need to be slightly longer as the spring is slightly thicker thru the middle.
i'm confused....
Had to go with grade 8 bolts as grade 5 not readily available over the counter here.
Actually pulled it all apart, then realised I needed the longer bolts,
But on Saturday all the industrial supply places are closed....
Being a fitter n turner, I tend to over analyze things.... have measured multiple times already,
And will check again when I mock install....
