Fan Speed Ideas
Fan Speed Ideas
I have all speeds but the high speed on the blower fan. Here is what I know.
- The fuse on the orange wire is good
- On high or really all speeds the orange wire on the blower relay is +12
- The resistor pack appears to be good and it ohm's out ok.
If I have all the lower speeds the blower motor is good - correct?
I am thinking the blower relay has a problem. Thoughts or what to ck is appreciated.
Does the hi speed fan relay operate when you switch to hi speed?
On my '71, when the relay operates, it connects the orange wire (12v) to the purple wire (power wire to the fan).
Check this thread:
https://www.corvetteforum.com/forums...tor-again.html
The orange wire is always hot, providing the fuse is good going to the horn relay connection.
Check this thread:
Check this thread:
It was a while back on actually two of my Vettes, and I can't remember if my problem was NO high speed or ONLY high speed.
Opened up the relay and dragged a piece of sandpaper through the contact points.
Fixed it.
Fixed it.
