79 vette hard to restart. Water in gas? Flooded?
Old 09-13-2015, 08:40 PM
superdave269
superdave269's Avatar
Default 79 vette hard to restart. Water in gas? Flooded?
Gassed up my 79 and took it for a ride. It ran rough at a red light and then stalled. It didn't want to restart. After a while it did finally start. Got the car home (had to hold my foot on the brake and the gas at times to keep it from stalling) I think maybe when I filled it up (a half hour before it started running poorly) I got water mixed in with the gas I bought. So I believe that why it ran so bad and I think I flooded it when I tried to restart it. So Now what should I do??? I will put in some Heat(dry gas) Since it hasn't been tuned up in a while I was thinking about putting in new spark-plugs. My hope is with new plugs it may start a little quicker and I won't have to worry about it flooding again. Any ideas?
Old 09-13-2015, 08:48 PM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
You can pour in a pint of rubbing alcohol. It will absorb the water and burn it off.
Old 09-13-2015, 08:50 PM
superdave269
I never hard of using rubbing alcohol. I may actually have some around. Thanks
Old 09-13-2015, 08:52 PM
derekderek
derekderek's Avatar
Received 3,388 Likes on 2,633 Posts
use dry gas. rubbing alcohol is already 30 to 50 percent water. is there a drain plug in the bottom of these tanks?
Old 09-13-2015, 09:06 PM
Big2Bird
Big2Bird's Avatar
Not that I have seen.(Drain plug)
Isopropyl is 30% water, but it is still hygroscopic at that ratio. I have used this trick safely before.
Old 09-13-2015, 11:25 PM
havesometo
havesometo's Avatar
I have used the Valvoline water remover in the past and it works pretty good.
http://www.autozone.com/fuel-and-eng...ver/33412_0_0/
Old 09-14-2015, 03:26 AM
toobroketoretire
toobroketoretire's Avatar
You may have a failing distributor module. Stick a 1/4" X 3" bolt into a spark plug wire and clamp the wire near a good ground. If the module (and coil) are good it should produce a 1" long blue spark.
Old 09-14-2015, 06:42 AM
Big2Bird
Big2Bird's Avatar
That is Isopropyl alcohol.
Old 09-14-2015, 06:56 AM
derekderek
derekderek's Avatar
yes but the drug store variety is cut 30% with water already. uses up a lot of it's ability to absorb water...
Old 09-14-2015, 07:14 AM
Big2Bird
Big2Bird's Avatar
And the Valvoline MSD sheet says 60% alcohol minimum.
Old 09-14-2015, 08:05 AM
superdave269
[QUOTEYou may have a failing distributor module.][/QUOTE]
I was wondering that too. I have heard that they sometimes fail when hot. The car was hot when this nonsense started. Looks like some dry gas and a new module are in order. Then I will double check my carb adjustments just for good measure.
I appreciate everyone taking some time to help me.
Old 09-14-2015, 02:02 PM
superdave269
Crossing my fingers. I just replaced the ignition module. It fires right up. Time will tell I guess. Bad part is the plastic connect that has what I believe as a condenser fell apart in my hand. Its together but not well. Do they sell that part too?
Old 09-14-2015, 03:12 PM
dochorsepower
dochorsepower's Avatar
Also check the condition of the power wire terminal to the distributor. It can get corroded over the years and cause the problems you describe. How do I know?
Old 09-16-2015, 08:05 AM
Big2Bird
Big2Bird's Avatar
If outside on the white tach wire, that is a tach filter.
Old 09-16-2015, 08:26 AM
Jud Chapin
Support Corvetteforum!
Jud Chapin's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
FWIW, I've been driving for over 55 years and have never had a "water in the gas" problem. I've heard this complaint over and over when a car doesn't run right (even from yours truly). You probably nailed it with the new IM. Hope so. Just my 2 cents.
Old 09-16-2015, 08:42 AM
speedreed8
speedreed8's Avatar
[QUOTE=superdave269;1590489370]Crossing my fingers. I just replaced the ignition module. It fires right up. Time will tell I guess. Bad part is the plastic connect that has what I believe as a condenser fell apart in my hand. Its together but not well. Do they sell that part too
yes
http://www.summitracing.com/parts/pnx-d9007/overview/
Old 09-17-2015, 09:03 AM
superdave269
Thanks, The part from Summit is exactly what I think I should replace as I am concerned with the plastic falling apart one of the connections could touch the distributor and cause a short.
To 79 vette hard to restart. Water in gas? Flooded?
Quick Reply: 79 vette hard to restart. Water in gas? Flooded?
