Half shafts
Old 09-28-2015, 10:36 AM
terrys6t8roadster
terrys6t8roadster's Avatar
Default Half shafts
My 6t8 came with the smaller diameter half shafts. Are the 3" shafts stronger? I located a pair from a 75, but heard the thickness of the tube wall was thinner. T
Old 09-28-2015, 11:28 AM
lionelhutz
lionelhutz's Avatar
People with lots of power seem to be able to twist-up the larger diameter factory shafts fairly easily so I don't think they're a worthwhile upgrade.
Old 09-28-2015, 11:50 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi T,
All 58-72 cars were equipped with the same half shafts regardless of engine option.
The difference was in the fastener hardware used on the half shafts' u-joints; straps/nuts on the lower hp cars and caps/bolts on the higher hp cars.
Regards,
Alan
Old 10-05-2015, 06:43 AM
terrys6t8roadster
Guess I'll stay with the original shafts and see how they hold up behind the upgraded engine. T
Old 10-06-2015, 12:33 AM
Kid Vette
Kid Vette's Avatar
These are stronger. 1963~1979 CORVETTE REAR AXLE HEAVY DUTY STEEL HALF SHAFT DRIVESHAFT ASSEMBLIES - 3" x .083"
Old 10-06-2015, 02:55 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
If you have more than 400 hp and intend on using wide, sticky tires, you might be better off with stronger half-shafts (aftermarket) AND safety straps around them.
If you just have good street tires, the stock shafts will be fine. You'll just make a lot of smoke.
Old 10-06-2015, 06:25 AM
terrys6t8roadster
Thanks Kid Vette, that's the type of info I needed. Any idea of the torque rating they have?
7t1, I have Dragvette's 6-link setup with outer half shaft loops, I expect with the Vortec S/C to have around 600 hp and am running Continental slicks.
So any info on heavy duty diff output shafts and outer axels would be terrific. T
Old 10-07-2015, 01:18 AM
7T1vette
7T1vette's Avatar
Internet search will find some custom alternatives. But, I would think that any good quality, well outfitted driveshaft shop would be able to make something out of aircraft quality aluminum (or high strength steel) tubing, if they had the joint caps for the ends and the length required. You just need them made out of a material that can resist the torque spikes you might get from high-power starts.
I'm not sure what the material spec was for the stock half-shafts. But, I'm guessing that it wasn't any exotic stuff which would cost more money.
Old 10-10-2015, 03:29 PM
RBrid
RBrid's Avatar
Question: Are BF Goodrich Radial T/A 295/50/15 considered sticky tires or good street tires? I'm trying to figure out how heavy my right foot will be able to be when my '77 is completed. Thanks!
Old 10-10-2015, 11:54 PM
7T1vette
7T1vette's Avatar
T/A Radials are just decent street tires.
Old 10-11-2015, 12:43 AM
RBrid
RBrid's Avatar
Thanks 7T1vette. I was concerned that the '295' would put them into the sticky category.
To Half shafts
Quick Reply: Half shafts
