Different rear bearing carriers?
Theses bearing carriers are from my 72 vette. They are different.
Pic 1 the size of the area that the shock mount/bolt goes through are of different diameter (read arrows).
Pic2
The internal area were the bearings are held on the top carrier is a solid piece of metal. the lower carrier has a cavity. See the white arrows.
The rusted carrier is from the drivers side and was in great shape. the PS side carrier was hard to remove and seems worn on the external surface.
Which is the correct carrier or can I use them both.
Pic2
348103 and 348104 are the correct numbers, I can't clearly see the other number in your pictures. I did find that 348103 also had a number of 3820643. The same parts were used from 63 to 82 so the numbers changed. If neither one of them has an issue you can use them.
The poly end will rub on the 72 housing but not on the later one. The heim joints work fine on either. Strut rods are a bad place to use poly bushings. It's best to use the heims.
Mike
Mike
