Which camshaft to purchase.
With an otherwise stock L-48 and limited by budget I'd go w/ the K1102 summit cam or an XE256H. Particularly with those rear gears. Just looking at the graph for the XE256H tells me you're shifting power up out of the comfort zone of the build.
With an otherwise stock L-48 and limited by budget I'd go w/ the K1102 summit cam or an XE256H. Particularly with those rear gears. Just looking at the graph for the XE262H tells me you're shifting power up out of the comfort zone of the build.
http://www.compcams.com/Technical/Dy...62H-10_001.asp
http://www.compcams.com/Technical/Dy...50H-10_001.asp
And for completeness' sake, the XE256H:
http://www.compcams.com/Technical/Dy...56H-10_001.asp
So yeah, all said I think I'd go w/ the XE250H. When the budget opens up, he can go bigger. This cam should enhance the torque of the car everywhere and add just a little bit more upper RPM power.
Isky 262 supercam with 208-208 on a 108 lsa is a good cam for low c.r. 350. Had a friend use one in a stock 350 in an el camino and it had much better low and mid range and actually got decent gas mileage too.
Leave it alone ..You will be lucky to get 200hp with a cam only change .
My point of reference is the L82 which required Different heads and cam to make 225
My stock L-82 with no emissions and dual exhaust produced 233 RWHP on the dyno and forum member Karol's L-82 with stock heads and unknown cam with 2.5 inch dual exhaust produced 248 RWHP on the same dyno. 233 RWHP and 248 RWHP equates to about 275 Net HP and 290 Net HP versus the stock L-82's 220-250 (1974 L-82, the last year with true duals) Net HP.
I am a big block guy, kind of. But as my engine builder told me when I had my motor built, unless you get it to breathe, its really not going to do much.
I know your budget is 200.00, but speed is a question of money, how fast can he go? If your cam change gains you only 10-15% hp increase, it seems like spending that would be better spent tuning it and making it run better would get you the same results.
Good luck.
Good luck.
If he is really adamant about doing this, and staying under $200, the Summit Kit is likely the only way.
http://www.summitracing.com/parts/sum-k1103/overview/
with
http://www.summitracing.com/parts/sum-174001
and
http://www.summitracing.com/parts/sum-g2660/overview/
choose a cheap one of these
http://www.summitracing.com/search/p...rder=Ascending
Puts you at about $210 plus tax.
The smaller 1102 kit MAY be a better bet with that motor, and you might not need to mess with valve springs. But, I will let someone else comment on that.
http://www.summitracing.com/parts/sum-k1102
with
and
I agree that using house brand parts like this is your only option to do it with a $200 budget because you will need the gaskets, timing set and valve springs as a minimum on top of the cam and lifter kit. Are you planning to ship to the border and pick it up because shipping across the border will add a fair bit.
I also think the XE268 cam is just too big for the rest of the combo. If you had more stall and more rear gear you could probably pull it off but not with what you've got right now. A cam with the intake duration somewhere around 210* @ 0.050" lift is likely about the most that should be used.
Maymyvetteliveforevr (10-13-2015)
I'm helping my friend remove the trany and engine to replace main seals on both and do other minor work and thought with a budget of say $200.00 we could add a bit more hp by changing the cam since he feels the lobs maybe wearing.
Thanks for the suggestion, I'll give him that advice.
I checked the specs on the cam and it seem a bit too mild, I don't know if that would make a noticeable improvement. Please correct me if I'm wrong.
This sounds like a good choice. I found the cam and lifters on Amazon, but couldn't find the package you're referring to.
Comp Cam XE262H
For the horsepower increase his budget is around $200.00 U.S. (parts only) and I'm helping him with the install so labour is free.
Comp Cam XE262H
One of the first motors I modified in the mid 80's was a late 70's 350 L-48 totally stock except for a dual exhaust, Long Tube Headers, and an Edelbrock SP2P intake ((no longer made I believe..single plane/dual plane). Frankly the engine was a dog in this configuration. In an effort to get some more power out of mill, I swapped just the stock cam, nothing else, and with a car that had a Turbo 350 auto and 3.08 gears.
The stock L-48 cam specs are:
Lift .390/.405, duration 195/202, LSA 112
I choose a comp cams 260H (this cam is still made by comp cams):
Lift .440/.440, duration 212/212, LSA110 Operating range of 1,200-5,200 RPM.
The cam transformed the engine...designed for low end grunt and good mid range power...perfect for 3.08 gears and an auto. The car was a blast to drive and MUCH better than the L-48 cam with the 260H having almost as much lift as the L-82 cam with lower duration. It can be done!
Dr. Detroit
Received 3,892 Likes
A Comp XE268 is an excellent cam.....
It will give you the 30 horsepower you are looking for....
Team it with a Performer EPS intake and a quality set of headers.
You will like it a lot.
Stock heads or not...you will see improvement.
Use an Elgin spring kit and new valve seals when the cam is installed for max performance.
The Elgin Z-28 spring kit is inexpensive and perfect for .470 lift flat tappet.
A flat tappet cam is fine if broke in properly. Do not listen to naysayers....it can be done.
Jebby
Jebby
You all know his budget is 200.00 .. Oil , anti freeze , gaskets , timing chain and gears prevent getting any cam shaft LMAO ...
Built many low buck 350s over the years, and from what everybody has already mentioned keeping the combination matched is the secret.
I have used Edelbrock Performer cams in the past, and believe it or not,...they work well for stock type builds. The intake duration is 204 @.050, so it's not that much bigger than stock, but it'll make a 190 hp stock engine feel like 300 hp. Throttle response, low end torque, will work well with a stock converter, and gears.
As for a $200 total budget,....I am afraid that's not going to happen these days.
#33
Thanks everyone for your reply.
My friend and I had a long conversation this past weekend about the cam install as well as other "wish lists"and we decided that $200.00 is no where near a realistic budget. In my opinion I'd say at least $500.00 so this is on the back burner till we review the other "to do" and "wish list" budgets.
We noticed also that the floor pan is rusted and needs to be replaced along with the carpet, so that takes priority.
Thanks again.
Thanks again.
#34
That's the best choice at this point Frank. Maybe there will be some good Black Friday sales and he can start putting together a well thought out combination.
Maymyvetteliveforevr (10-16-2015)
#35
I went the route of an entire engine rebuild. Dropped off the block crank and rods at the machine shop and let him do his thing. The result was 350 hp and 390 tq on the dyno. He used a comp cams dual pattern camshaft, and reworked a set of 882 truck heads. He offers this combo as a crate motor. With a Eddy dual plane and 670 holley the car is a blast to drive gets 20mpg.
#36
Correct me if i am wrong, but I thought that the only differences besides the forged crank and pistons were the compression ration, aluminum intake and camshaft and I thought that both the l82 and l48 used the 882 heads. I could be real wrong about this and if so please school me as I've not ever owned a l82 but only going of what i seem to remember reading here on the forum. I only ask as now I'm confused about the topic.
#37
Most specs i have read say the L82 had 10-20 hp more than the L-48? and the only change was a slight increase in compression. At the end of the day, you need 300 plus hp to make this car a fun car to drive. Save your money and buy a crate engine. or have local shop build one.
#38
Most L-48's are about 35-60 HP down over an L-82. For example, a 74 L-48/L-82 rated @ 195/250 (Gross) and 78 185/220 (NET HP).
1978 L-48 versus L-82
Cam lift .390/.410 versus .450/.460
Bigger values on the 882 heads for the L-82
Compression 8.5 versus 9.0 (8.9)
Forged pistons, forged rods, forged crank versus cast iron components
Cast iron intake versus aluminum intake
and other differences...
A properly setup up L-82 (timing, emissions delete, dual exhaust/headers with freeflowing mufflers) should make about 275-280 NET HP (330 Gross HP), versus a stock components L-48 with the same mods. A stock L-48 with the same modifications should make about 225 NET HP,same as a factory L-82 with no mods. The 72 LT-1 rated as gross HP 330 was rated as 255 NET HP in 1973...same motor, almost exactly.
#39
Oh ok your the winner. My Dodge caravan makes 250 hp with its V6, doesnt make it anymore fun to drive.
#40
I agree with Jebby. One thing I would add is if someone could do some bowl work in the stock heads that would help. It isn't difficult costs basically nothing .
