Which camshaft to purchase.
Friend has a 80' Vette with the stock L48 motor and carb with the only upgrade being headers and wants to add a bit more hp by way of a camshaft only. I believe the stock hp was 180 and he wanted a but more hp by swapping it to the 460 lift cam.
I'm not that knowledgeable on today's camshafts availability so what would those that have done this upgrade recommend for an increase of about 30 to 40hp? Is that a bit to much hp increase to ask for in a cam only upgrade?
I am sure others will chime in and tell you that the time and money would be better spent on replacing the heads. Do a search for vortec heads here you will see the tech needed to make them work and recommendations for other heads.
Maymyvetteliveforevr (10-05-2015)
This would be better midrange and top end but requires cutting the spring pockets or beehive springs. http://www.summitracing.com/parts/cc...make/chevrolet
a flat tappet cam only will get you very little noticeable performance upgrade.
Received 1,468 Likes
Cruise-In II Veteran
You could get close to that with a roller cam upgrade. This upgrade requires new springs, pushrods, lifters. cam, cam button. To avoid having to cut the spring pockets you need to keep spring size down to about 1.25. This kit will work and maintain decent cylinder pressure and throttle response needed with the compression and differential gearing.
Thanks Mike, any idea what the brand and model of cam it would be so I can see about sourcing one. I'm going to take a guess that the average cam - gasket set would be around $250.00?
Just to emphasis, I did mention in my original post "Cam Only".
We believe that the lobes on the camshaft maybe worn due to it being the original camshaft, therefore doing the cam and heads is way out of budget.
Thanks for the reply but this would be about 4 times the budget and no feesable.
Unfortunately over budget since the cam also will be replaced.
if it were me on a tight budget I would save and find a running roller cam 350 then swap the intake.
Imo the owner should save a little more and do a head upgrade at the same time. I understand budget's, but you can get a decent set of heads at a pretty fair price with some good shopping. But to answer the question with stock heads and intake the xe256h would probably be my choice ecspecially given the budget and not being able to change the gears and stall converter to match the camshaft. Scroggin dickey performance has vortec heads for a fair price.
The stock L82 cam is a solid piece in the right build. Unfortunately it was originally the L46 cam and was designed for a 11 to 1 iron head motor. Put it on a 8.5 to 1 engine and in front of a 3.07 gear ratio it is a disappointing combination with a net loss in performance. If the only option you have is a flat tappet camshaft replacement change springs to match the cam specs, new lifters are required and upgrade to at least some new stock style rocker arms.
http://www.summitracing.com/parts/hr...make/chevrolet
If you go this route email me. I have a set of takeoff springs for it cheap.
DO NOT think this is just a "drop a new cam" in it and button it up with new gaskets. ANY cam swap will require springs, lifters, cam, and gaskets minimum. Long slot rockers should be used for a higher lift cam. You will likely find the timing gear is shot. By the time you do all this the roller upgrade kit I linked will cost you $3-400 extra with a result of noticeable increase in power throughout the powerband and no worry on wiping a lobe. This is why everyone is pointing you this direction.
I didn't have the money to go roller when I did my cam swap. Followed comp cams recommendation and went with the xe262h kit. Noticeable improvement but it was close to $300 if I recall but it came with everything springs, lifters timing gear and chain. Good luck
That would be a decent option. Really need a little better rear gear for it. The cam I listed might be available in a K Kit.
For the horsepower increase his budget is around $200.00 U.S. (parts only) and I'm helping him with the install so labour is free.
If you don't have enough to do it properly then recurve the distributor and what does the rest of the exhaust look like after the headers?
At $200 ($150 US) you are definitely looking at a hydraulic flat tappet cam. I always liked the Comp Cam XE 268 but with the stock l48 heads I doubt you would see any real benefit, maybe even slide a bit backwards.
Maymyvetteliveforevr (10-06-2015)
If he is really adamant about doing this, and staying under $200, the Summit Kit is likely the only way.
http://www.summitracing.com/parts/sum-k1103/overview/
with
http://www.summitracing.com/parts/sum-174001
and
http://www.summitracing.com/parts/sum-g2660/overview/
choose a cheap one of these
http://www.summitracing.com/search/p...rder=Ascending
Puts you at about $210 plus tax.
The smaller 1102 kit MAY be a better bet with that motor, and you might not need to mess with valve springs. But, I will let someone else comment on that.
http://www.summitracing.com/parts/sum-k1102
with
and
Thanks for the info, I'm sort of leaning towards the xe262h kit.
