Door Edge Repair Question
Received 2,878 Likes
Hi Steve,
I would describe that damage as being caused by someone not being at all careful, (careless), when they opened their door… not because it's 'susceptible' to damage. You have to hit the door into something pretty hard (and sharp) to damage more than the paint on that edge.
That repair needs to begin by having the paint completely removed on the outside AND jamb side so the extent of the damage can be seen and so that you can be sure there's not the beginning of any de-lamination.
I'd then cut some fiberglass mat into very short strands about (3/8" long) and use that cut fiberglass with resin to restore the fiberglass to it's original contour.
The repair's surface will extend considerably beyond the current damage because you'll need to create a tapered surface for the mat to bond to. You could likely end up with a repair that extends about an 1 1/2"- 2" beyond the damage.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
Thank You
ZIO
Bondo spreaders were taped on the back as fiberglass won't stick to them. That leaves a fairly smooth surface on the back. A little sanding with 80 grit finished off the back.
For what it is worth.
The photo's of the chipped up edges of the door do not require resin and fiberglass. YES...if a person wants to do it...go right ahead. The damage is NOT that severe to go through all that extra work.
But I can HONESTLY STATE that Vette Panel Adhesive in this area will repair it and make it solid. The edge of the door shown is not needing to be built out.
YES..I DO build out edges of doors when they have been butchered and damaged like 'zwede' has shown in his photo's. And how I build the edges out all depends on the level of damage.
DUB
DUB
