Just picked up a T56 to swap into my '79
#41
Not sure if you are on TGO, but this dude only wants $160 shipped:
http://www.thirdgen.org/forums/engin...wheel-t56.html
2pc RMS T56 flywheel.
-- Joe
-- Joe
#42
I went ahead and ordered the RAM-1510 flywheel from summit:
http://www.summitracing.com/parts/RAM-1510
I also ordered some heads and a roller cam. Time to make this thing scream.
#44
-- Joe
#46
Thanks that's just what I needed.
You have been tremendously helpful, thanks so much!
I'll keep posting when I have updates. I haven't ordered any throwout bearing shims yet. I noticed that there is 3pc shim kit for $40 floating out there which seems a bit steep.
#48
Popped one of the heads off. Turns out someone has already bored this block .030 over and installed forged flat top pistons. Nice. Now I know I have a 355.
#49
What heads are you running?
-- Joe
#51
Blue Print H8002K 64cc heads with 195cc intake:
http://www.blueprintengines.com/inde...cylinder-heads
I'd run a 224/230 (@ .050") cam. Would be a mean little street motor.
-- Joe
#52
Here's the cam I went with:
http://www.compcams.com/v002/Pages/396/XR276HR-10.aspx
Blue Print recommended the XR282HR but I went one step down, giving up a bit of top end HP for a lot more torque. I'm confident it'll deliver well over 400 ft lbs, hoping to exceed the 400hp mark too.
#53
Will be a fun driver!
Double check your water pump to timing cover clearance. You may need to kiss the bolts on the back of the water pump with a grinder. If they put pressure on the timing cover it will preload the cam.
-- Joe
#55
Progress has been slower than planned but its okay. I've been figuring things out as I go. The cloyes timing cover didn't clear the larger harmonic balancer or the water pump. Ended up getting a smaller balancer and picking up some spacers for the water pump and main pulley. Pain in the butt.
Ended up picking up a new clutch and pressure plate kit rather than dealing with the pressure plate that came with the trans. The fact that a replacement clutch disk is $280 and the entire kit is about $330 made that decision a little easier.
Still not sure what I'm going to do for a crossmember. I might need to find a local fabricator to help me out when it comes to it.
#56
This is the Cross Member from Bowtie. Everthing fit for my 78 except the height of the plate ( shimmed the transmount ) base of the plate was to long. Cut the end off and welding under the plate. Also you will need to make adjustments to the parking brake wheel, the braket is to far forward so the parking brake cable will not be tight enough. I used a 3.5" dia wheel to make up the slack.
Now you are using a T56 vs my T56 magnum. I believe the tail housing is different so you may not have similar problems, except for the parking brake issue.
You can see this in my install notes.
https://www.corvetteforum.com/forums...-corvette.html
#57
That's interesting.
I still don't know what the answer is for me. My C3 is an original 4-speed and has the non-removable crossmember. I need to make a friend who knows how to use a welder better than I do...
#58
The engine with its fresh top end along with the T56 behind it are finally in the car:
More pictures.
Trans under the car:
The trans mount is really right above the factory crossmember. If the crossmember was removable, fabbing something to work wouldn't be too bad.
Shifter position. There is green masking tape covering the hole for the shifter. It'll be moved over to the right a bit but should be fine. I intend to build a custom center console anyhow.
More pictures.
#59
C3 of Year Finalist (track prepared) 2019
You can easily put an offset in the lever to put it in original location through the console if you prefer. I have a Tremec TKO in my car that doesn't have a corvette specific shifter - like you, I had to open the hole in the floor (and sealed it with an aftermarket boot), but I cut and welded an offset and twist in the shifter so that the lever comes through the console at the same location and angle as original. I then fit a Hurst factory style lever and it looks identical to how it did with the 4 speed.
As for the mount, if the mount is directly above the crossmember, can you not just bolt the gearbox mount to the crossmember and to the gearbox, with spacers or some box section in between if needed to raise the mount?
Looking good by the way.
#60
I'm not really worried about the shifter placement in the console. You can see in this picture what a previous owner did:
Attachment 48359901
I'm really leaning towards just making a custom clean center console. Thinking of locking the HVAC stuff to cold / front vents and just setting up a **** for the fan speed and a button for the A/C compressor. I'll never need heat or defroster in this car.
As for the trans mount. If you look at the picture closely you might be able to tell that the top of the trans is touching the body of the car and there is not much space between the trans mount location and the crossmember. I do think that crossmember is going to have to come out.
I wonder what it would be like if I just bolted the trans directly to the crossmember with maybe some poly padding or some crap in between. Seems like a bad idea but maybe not?
Attachment 48359901
