Ignition Timing help 427 Tri-Power 400HP
I just upgraded my Ignition system with the following MSD products.
Distributor: 8572 with vacuum advance
Ignition: 6425
Coil: 8202
Spark Plug Wire Set:35379
What is the difference with running vacuum advance vs mechanical?
Also, what timing should I be looking at?
Thank you,
Carlos
Ignition: 6425
Coil: 8202
Thank you,
Carlos
