Plug Wire thru motor mount
croaker (11-04-2015)
Received 2,878 Likes
Hi C,
One way that makes it some what easier is to push the distributor end of the wire through the mount and then pull the rest of the wire through and on to the distributor.
The boot for the distributor is smaller than the spark-plug boot so fits through the space between the mount and block pretty easily.
Regards,
Alan
Regards,
Alan
since your profile shows you have a modified engine have you considered running the wires along the lower edge of the valve covers and coming down from there?
Drivers side isn't bad but passenger side I cut the old wire and taped it to the new wire. Obviously I removed the boot and then I pulled it through the channel and behind the mount. Worked well and was easy.
