Headlight motors
The ORIGINAL and bestest
Toronto Events Coordinator
They are basically the same motors, the Probe used Mazda RX-7 motors, so whichever you can find easier and cheaper will work the same.
Received 3,220 Likes
The only difference between the Probe 93-97 motors and the Miata 90-97 is in the wiring.
The Maita has an extra wire to illuminate a dash light.
The Probe 89-92 uses a different motor.
They made about 3/4 million Probes as opposed to 1/4 million Miatas.
Here's a link how to test the motors-on my website-w/ wire colors
http://www.stingrayv12.com/installation.html
Richard
Richard
Thanks!
Richard
Richard
Hey Bruce-
They certainly could be used-
There are basically the same-the wiring is different- uses the chassis ground as part of the switching so a PWM wouldn't work. And from what I have read the motors aren't as robust as the newer ones. I know my Brother's Miata has almost 260K w/ the original headlight motors. The junkyard I've been to hasn't had an older one to actually check out
and not to mention Mitas have a following and are usually parted out quick..not so much for the probes.
Hey Bruce-
