header primary size and collectors
You - tube again.
Under summit racing quick flicks
... how to select header primary tube diameter...
... collector size selection...
This may be useful to you if your good with math and he uses a 350 as an example. But all you have to do is know one cylinder cubic inch.
Merge collectors are the way to go. Why don't you just add the link to your post?
