reassemble lower horn contact steering column
Cruising
I have been attempting to reassemble the steering column on a '79 C3 after replacing the ignition switch. After laying out all the parts, I have 2 components I cannot remember how they came out:
One is a lower horn contact
Another is a spring (roughly 1 " in dia)
I have tried to find a diagram showing these components, but none a clear enough to complete the puzzle - I am stuck!!!
DUB
Cruising
Clarification: This is a much smaller spring - possibly related to the lower horn contact? Where do these
two items fit? Trying to include an image. Thanks
The donut-shaped piece appears to be part of this assembly While it may be due to the angle you took the photo, it would appear that the "L" shaped section of that piece has broken off.
I'm pretty much clueless regarding the spring. It doesn't appear to be part of this assembly as it looks both too fat and too short. Perhaps it is the return spring for the headlight bright/dim switch that's part of the turn signal switch. Does the switch spring back after you pull it forward?
autoenvirons (11-28-2015)
Cruising
The image shows a different perspective on the part in question. it is similar to the part you tagged, but i have that part as well.
The turn signal lever springs back properly when pulled forward.
Do you mean that you have the entire assembly that includes the ring-shaped part in the picture? If so I see no other piece in the parts illustration for the entire steering column that it could be. If now separate from the rest of the upper contact assembly you have to reattach the ring-shaped part using the plastic retainers.
I'm nearly positive that the spring is part of the hazard switch **** assembly. It fits between the two pieces that make up the hazard switch ****. It doesn't show in the parts illustrations in my manuals but I checked mine and it is definitely spring loaded and that one looks like both the right size and strength for the job.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This page will show you how to assemble the top part of the column. Just click on supporting document. +
Mike might be right, that may be the spring used in the hazard know. It's not the lower contact spring...
And.. You're missing the upper portion and insulator in your upper contact
1969-1982 Corvette Turn Signal Switch Installation
Here is the lower contact installed.
The ONLY place that I can think of inside the steering column where that light spring goes is for the lever you press down on when you take out your ignition key.
The other is PART of your upper horn contact...
DUB
DUB
Cruising
I wish that were the case; however, I have the component you show IN ADDITION TO the part I showed. It looks exactly the same except it is not attached to another component. I am at a loss where it might fit.
I thought that was what it had to be as you shouldn't have been deep enough to disturb the key release. To confirm simply see if the two pieces of the hazard switch button have a bit of resistance between them and that the inner piece is always held against the column no matter the switch position. (I think the switch will work without the spring but you'd get a rattle as the inner portion bumps against the column.)
For some reason it looks like someone left behind part of the upper contact. Perhaps they lacked the proper shims and substituted that? Did you find shims behind the upper contact? Did your horn work before?
The following 2 users liked this post by SwampeastMike:
autoenvirons (11-29-2015),
DUB (11-29-2015)
Cruising
That is an excellent working theory - the horn worked originally (I think) - I took pictures during disassembly, but none captured this extra piece -
DUB
autoenvirons (11-30-2015)
