Need part numbers for clutch, pressure plate and flywheel for 68 427.
Hi, I need the part numbers for the clutch, pressure plate and flywheel and throwout bearing for 68 427. I believe it is the 11 inch setup?? Oh, also need part number for pilot bearing. Is there any advantage of using a roller bearing in place of pilot bearing? I see them advertised now and then.
Thanks!
Thanks!
Thanks!
Thanks!
The part numbers for the individual parts will vary from vendor to vendor but any auto parts store can supply a quality rebuilt clutch kit. And there is no real advantage of using a roller bearing instead of a bronze bushing because both styles will easily outlast the clutch plate.
Thanks for the response.
Appreciate the response.
