Cam for stock L48
7th Gear
Cam for stock L48
OK I'm about to install new Chrome timing chain cover so since I'm halfway there I thought about installing a new cam. In the last month I have refresh the old heads. Installed an edelbrock rpm performer intake and re-built the Q-jet carburetor. Installed hooker headers. Advanced the timing useing Lars info.
My ? is what Cam can I install with what I have which really a stock motor with bolt-ons. Is there a Cam that can use the stock lifters?
Also what muffler do you recommend, looking for something a little quieter that 40 seires flowmasters.
If you're running the stock rear gears I would install an RV cam that has a higher lift but not much more duration. Rumpety rumpety cams may sound really cool but they need lower gears and higher compression to work.
Did you change the valve springs when you "refreshed" the heads?If not then you would need to do the springs as well.
Have you driven it since the headers and distributor tuning?That should have made a big difference.
I would consider saving my money and doing a heads/cam package down the road.
As for mufflers the Dynomax super turbo gives a good note without being obnoxious.
The Dynomax VT will be quiet at cruise and around town but scream when you mash the pedal hard.Other options like magnaflow or the dynomax ultraflo will be louder but not as bad as the flowmasters.
Comp Cams XE256H. is a great cam for that motor w/stock heads
Received 3,043 Likes
St. Jude Donor '05
torque IS what presses you back in the seat and gives you that feeling
Head upgrades are nice but why not just change springs and go wih the 256 cam it will run well. Dont want to throw a ton at a stock motor like that...spice it up some then drive it while you build something bigger
I tried the cam with stock heads when I first got my Vette many years ago and was disappointed, not really much change in power. I would save and you could go with aftermarket heads and cam, that's where you really feel the difference.
All these upgrades (intake, cam, heads, exhaust, ignition) work together to get maximum benefit. If you only do part of the system the things you do will generally not reach their full potential.
Do you have an Automatic or Manual. Big difference in how to set up, because with the Auto, it's best to upgrade to a quality torque converter to get all you'd want out of it. The L48 is like any typical SBC. And as softwarejanitor pointed out, it's best to do all the upgrades at once.
