Lets shut off the heater blower
From what I have read on the forum, when the A/C is turned off, the blower keeps running on low speed.
I have done a A/C delete, everything works perfect, wow is it cleaned up under the dash. However, my Blower keeps running on lowm all the time the key is on. This is just needed wear and tear on the blower motor.
Has anyone figured how to make the blower stop running when you set all the HVAC controls to OFF.
I am sure its been covered here at some time, but with my very slow 24.4K dial up, I just cant do extensive searches.
Thank You
8Valve
Thank You
8Valve
Received 1,468 Likes
Cruise-In II Veteran
IIRC: remove the tan wire from the HVAC control plug.
On my '78 I pull the plug off the top of the fan box under the hood.
Pass side near the hood latch. 3/4 wires if memory serves, in a "L" configuration. Pull it straight up. No-Mo-Fan
Not my car,........RED SQUARE:
Thank You
8Valve
Thank You
8Valve
if your blower fan never turns off your BCM (Blower Control Module) may be faulty.
Welcome to Deep in the Mountains, My Home......Hosted by Rod Sterling
Dial Up Internet, 24.4K No large Pictures Please, they overheat and melt my Modem. High Speed Internet available in the Village library, they have 3 computers but waiting lines
Yes, Telephone, main cable up the mountain is the old paper wrapped insulation with the lead jacket cover. We are scheduled to get fiber optic next summer
Yes, Electricity, frequent power failures is a way of life
Crime, we hear about it on the evening news
Cell Phones, Naw...no jails in this area. Cell phone RF Black Hole
Nearest Traffic Red Light 22 miles
Nearest Walmart and McDonalds 22 miles
Nearest Movie Theater, south 90 mile RT, North 150 Mile RT
Nearest fine dining, same as movie theaters
No Poison Snakes
No Alligators in the Lake
No Hurricanes, Tornadoes, Floods, Oppressive Heat, No Scorpions, No Tourists
This is the best place in the US to live.....Seriously
ALl you have to do is get used to a Max of 45 below and deep snow in the winter
8Valve
In a '79 the blower runs on low speed with the key in the "run" position.
This was a feature called "constant ventilation" by GM. I'm not exactly sure when or where it began within the divisions but by the late 70s it was ubiquitous.
8valve, Where is "here"?
SwampeastMike is right. No "off" for the fan. Just "low".
I run a 1/2 turn stainless ball valve in the top heater hose and pull the plug that connects the fan (pic above). Saves me some grief in the summer.
I too recall this topic being covered.
I think poster indicated GM had the fan run on low continuously
to prevent the build up of hydrocarbons inside the cabin.
It is not in my 68.
The fan can be switched off.
The Astro Ventilation idea was supposed to vent the cabin.
Maybe this was a continuation of that idea.
Marshal
It is not in my 68.
Marshal
When I got my 77 I opened the relay (a few bent tabs) on the firewall and put something non conductive between the 2 contacts that kept it on all the time. It's now 3 speeds but that's fine.
In my experience it is the lack of use that generally causes the death of high-quality permanently lubricated motors of the sort used for blowers in vehicles.
If you have a problem with excessive cabin heat in a '79 you might have a problem similar to mine.
The control cable for temperature runs to a lever installed behind the glove box. When fully at the "cold" position an arm on the lever presses a vacuum switch that opens to in turn open a water shut-off valve installed in a heater hose in the engine compartment on the passenger side that leads to the heater core.
At some point in production, they started using a different version of the shut-off switch that instead of a good-sized "button" like head (contacted by the lever) used a small diameter, medium-soft plastic extension on the switch shaft. If the lever isn't perfectly lined up (mine isn't) with the switch shaft extension it will eventually bend and/or fall off. Once this happens the switch will no longer be operated, the hot water shut-off valve will never close and you will roast in the cabin. I fabricated a new shaft extension using a child's fat pencil and epoxy and to my surprise everything worked perfectly and I no longer get excessive heat in the cabin.
