Opinion needed on 76 gas tank with the bladder
Just pulled my tank because I'm replacing the sending unit and wanted to get a good look inside the tank. The inside of the tank looks good and the bladder looks to be in good shape and it doesn't leak. My question is, what's the life expectancy of these bladders and how reliable are they? Could I get a few more years out of it? I would rather not have to buy a new tank if these originals don't really have any issues.
I have never heard of one leaking unless it got crunched.
Went thru the same thing on my 76 about 2 years ago. Inside of tank looked perfect and had not been leaking. Installed new sending unit and put the stock tank back in. No issues at all.
Collapsed Gas Tank Bladder - 1975 Stin
I ran into a strange problem where the gas level got low and the bladder inflated. I could not figure out why it did that since both sides of the bladder are vented. I ended up removing the bladder and running an unlined tank with no issues. The bladder is a safety item for rear end collisions, but could be removed if deterioration becomes a problem.
The bladder will disbond from the tank and partially collapse inward, preventing the tank from being filled to capacity. Once that happens the only thing is to replace the tank.
Next questions, if the bladder is bonded to the inside of the tank why would there need to be a vent of the space between the bladder and the tank?, and other posts I have read said that the bladder can be removed if the neck/gasket area of the bladder is retained to seal the filler neck, any reason why I would not want to just remove the bladder. Every post I've seen state that the tank is super clean once the bladder is removed.
Gas tank bladder fixed
