L-82 to L-48 Oil Pan Question
Cruising
Hello All! I need to replace my L-82 oil pan and am having a heck of a time finding one. Would I have enough clearance to use an L-48 pan, if I simply took out the windage tray and replaced the main studs with bolts?
Oil pan
Long Island Corvette has what you need. Www.licorvette.com part # 38 26A. The drain plug is in a different spot that's the only difference.
Cruising
Thanks Zoix, however that doesn't look like my current pan on the inside of my 75. Mine only has side scrapers and a rear sump baffle. The pan I tried that looked like this wouldn't fit.
Cruising
have you looked at Chevrolet part number 360450
http://www.summitracing.com/parts/nal-360450
When I rebuilt my L-82 in 2014 I looked to replace the OEM pan since it was a little beat up on the pan flange...no luck finding an L-82 OEM type pan..they are not available. I reused my L-82 OEM pan after cleanup and flange straightening.
How did you determine it is not available? see link below
http://store.revolutionparts.com/gmp...0/?parent=1112
