getting rid of the smog pump
How can I get rid of the smog pump and still pass the smog test? Let me clarify the fact that I live in Ca. my car is a 1981 Corvette. I know the newer engines don't run smog pumps. I want to know how to make the engine smog legal without the smog pump.
What yr and what state do you live in?
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
Out of curiosity, why do you want to get rid of the pump? There is no performance advantage to deleting it - the A.I.R. pump absorbs almost no power off the engine when it's actually pumping, and operates most of the time (and when the engine is under power) in a free-wheeling condition that takes about as much power as an idler pulley.
You cannot pass a smog test with the pump removed - all smog tests I am aware of include a visual inspection of the components. If you are required to pass smog, you need to keep the pump. Which, again, has no realistic impact on performance.
Lars
Lars
Don't know we're your from, but before alaska did away with our smog testing if your vehicle didn't have all the oem smog parts, you would get denied, you could then challenge the decision and pay to have your exhaust anylized if it was as clean as what the oem exhaust was you passed emissions. Some states don't make vehicles over 35 years test.
Received 1,469 Likes
Cruise-In II Veteran
This question cannot be answered since every state's inspection procedure is different.so it depends upon what state you are in. For example, in RI where I am cars are exempt from emissions inspection at 25+ years and older. In Mass next door, no emissions inspection at 15 years and older, others emssions inspection never expires depending on the state etc. In RI there is no visual emission inspection...just need to pass the sniffer if you qualify for that inspection, same in Mass..just need to pass regardless of equipment on vehicle. Every state is different.
As for the AIR pump and assorted other clutter, it does not do a whole lot to clean the exhaust (I used to check with and without the AIR pump belt hooked up on inspections way back) and its effect on performance is negligible but when I put my headers on I did note that those ports extend WAY down into the head surely disturb the exhaust exit into the manifold. No real reason to keep it on the car (but do SAVE everything) except originality.
Here is a personal example of an emission part on a newer vehicle and its overall effect on emissions:
Just an FYI...I finally managed to block the EGR valve on my 1994 Mustang GT without setting the check engine light (car has 4 high flow magnaflow cats in the magnaflow X pipe...was all emissions legal up to this point) BUT...this EGR operates at anything off idle all the way to WOT and would cause the engine to knock/ping and get hot (everything was set correctly). Not only did the EGR blocking eliminate all drive ability issues completely but on the sniffer inspection the NOx emissions were SLIGHTLY higher but still well below the limit...I am talking about 10 PPM..makes you wonder....some of this emissions stuff is really ridiculous on old cars, rarely driven AND on newer vehicles some equipment is just overkill as demonstrated on my Mustang...Its crazy
The following 2 users liked this post by SH-60B:
76CSRvette (01-21-2016),
Jason Staley (01-21-2016)
We have them here in CO. They are located on freeway onramps.Three clean passes a few months before plates are due and no emission test is required.
Doesn't California have the 33 or 35 year old exemption? I think that they do, when AK did emissions testing most of what they followed was from C.A.R.B. rules with the exception of the 33 year rule, that CA had.
Your right, it don't.
Just to clarify... In California, even though vehicles 1974 and older are exempt from the smog check program doesn't mean you are allowed to tamper with the emissions system. Removing or otherwise making any emission device inoperable is still illegal, its just not enforced.
Back to the OP question, since you are in California, no, there is no way to remove the smog pump and still pass smog. If you remove the pump and all evidence that it was ever there(brackets, tubing, emissions sticker etc.) you MAY get lucky and get a smog tech that is too lazy to look the car up in the MOTOR manual to find out what its supposed to have on it and assume it didn't have A.I.R. but that is HIGHLY doubtful and still illegal.
There is the option of installing a different engine(same year or newer) along with all its emissions devices, taking to the BAR referee for a referee label, and then taking it in for a smog check(the GM e-rod engine package comes to mind).
You are going to have to leave it.
When it's time you will have a visual check looking for missing parts and Aftermarket upgrades. Timing is checked, EGR works and that you have cats installed.
Then they will load it on the dyno and do a 15 and 25MPH test.
If all is well you pass and are allowed to drive it for another two years.
