1/2 shaft came out of differential
I wanted to lube the u-joint between the differential and the 1/2 shaft. My wheels would only turn about 1/2 a turn in either direction so I couldn't get the grease gun on the fitting. Don't understand this as it was out of gear. I put the lug wrench on a stud and turned hard. The wheel turned past the tight spot but the yoke popped out of the differential over 1/2 inch. IS THIS NORMAL or am I in big trouble? I dropped the car quickly and it went back in. However when jacked back up it came back out. I just put a jack under the shock and lifted the car off the jack stands and it stayed out. Any insight would help me sleep better. Save my 69!!!
For the Yoke to come out they would have to be worn past the retaining snap rings. That means that your rear end has lots of metal in the gear oil.
Did the yokes also score the exterior of the diff housing? My original differential went in the dumpster because of housing damage and it didn't even qualify as a returnable core.
It is time to pull it out and inspect.
There is a c clip on the end of the side yoke to prevent the yoke from coming out of the diff. When the tip wears the c clip falls off and allows the yoke to come out. Sorry but you are going to have to remove the diff and make the proper repairs.
See post # 9 this is a picture of a good side yoke. I was lucky once that the clip just poped off as in this post.
https://www.corvetteforum.com/forums...-products.html
Nam Labrat
Received 4,178 Likes
Halfshaft hanging out of differential on one side..............
Snap ring missing on extended side (I pushed the piece back into the differential to show the empty groove)...............
Snap ring was behind the ring gear where it couldn't be seen/I "fished" it out to take a pic)............
Being a machinist I reworked the groove to be deeper and square-sided again/still within tolerance on end-play........so I replaced all the seals/bearings were in great shape/no metal or metal "powder" was in the housing/I cleaned, reassembled, and painted the unit..........
Doorgunner, that was lucky!. That is why I ask if the yoke had worn the outside of the case. That happens when the end of the yoke wares away
Nam Labrat
It looked like I caught it in time before the end of the shaft hit the crosspin too many times causing a big gap......like you said---the shoulder of the shaft and the seal dust cover would "eat" into the case.
Thanks guys. Sounds like I can't just reach in and snap the snap ring back on again huh?
Years ago I re-shimmed the rear spindle bearings. I thought this movement I had now in the wheel was the problem returning. I checked bearing clearance and it was still okay. When I rocked the wheel I could see the yolk going in and out. So this is the clearance that needs to be reduced? How is that done?
The outer spindle bearings are shimmed, and you would have to take the bearing apart, and install a thinner shim to tighten them up/ get rid of the play.
