What is estimated ET quarter mile with ZZ5 or ZZ383?
Last September I became a proud Corvette owner with a '72 Stingray.
Want to get an estimate about what my quarter-mile ET times would be with either a crate ZZ4, ZZ5 or ZZ383 engine?
I am running a new 700R automatic transmission with a 3.36 rear differential. I considered going to 3.55s, but my mechanic talked me out of it.
Most of the time, I want my Vette streetable - but I want to have wickedly-strong holeshot acceleration and 50-to-80 mph passing power when I want performance.
Want to get a conservative-estimate of qtr mile ET times - if I stayed with my 3.36 + new Raptor 700R four-speed automatic, what would be my quarter mile times under crate engine scenario ZZ4/ZZ5 or ZZ383?
I am considering a ZZ454 or ZZ502, but I am concerned about handling with the extra weight from a big block. Ready to sink about $8k - $12K P & L - but not $20K.
Talk to my friend Mike at Active Engines, he will steer you in the right direction as far as your goal are concerned.
http://www.activeengines.com/raceengines.shtml
3.73's Are The Best Rear End Ratio For TH700R4's
For C3's running TH700R4's the best rear end ratio of all is 3.73's as they'll give you the best quarter mile speeds and a 2050 rpm cruising speed in 4th gear. With the lower 3.73's you can run the quarter mile using all of the first three gears.
I'm glad you listened to him he's right. With that low first gear of the 700R4 and 3.36 is already low. Combine that with a torque monster of a 383 , upgrading to a 3.55 you might not go faster but you sure would buy new tires faster.
I'd be willing to be that the zz383 feasibly could crack the 11's with traction and good gearing, but I would expect low-mid 12's. The other 2 engines would likely put the car into the 13's.
Now on a simulator of the car changing rear gear ratio's the best drop was only .45 sec ET change from a 3.08
I believe Lower rear gears mainly help in the launch but after that it doesn't matter at the HP rating of Stock ZZ or 383 motors. Your butt sensor (feel) is what most use to evaluate the effect. I have yet not seen a lot to real track data to support the drastic effect of rear changes with these motors. Their are many running 12's, 11's with 3.73 and 383's but they are lightened and not stock builds.
Op, Congratulations on your new mistress. Check Out Mark Jones @ vortecproperformance.com best bang for the buck as far as Big block chevy's go and another place to check out is cnc-motorsports they have a wide aray of small and big blocks. I've never dealt with Mark, but if you research him you wont find a bad thing one about him, I have dealt with cnc-motorsports and they are Good dudes and good to do business with. When I built My 400" shp, I wish I'd thought more on it and built a big block instead just because it's easy to hit higher numbers with a bbc. I have a 454" on an engine stand in the garage and that will be the next engine that I build.
Look at the 4th engine, 660 horse and $7795 plus shipping. That should get you into high 10's if the rest of your drive train can withstand it. http://www.vortecproperformance.com/...binations.html
Last edited by bluedawg; 02-03-2016 at 10:29 PM. Reason: A pack of wild mice gang raping a cat...The is cat smiling...Yuk!
I think you oughta go with this LS3:
http://www.ebay.com/itm/Chevrolet-Pe...ZWrpar&vxp=mtr
Comes with a warranty I believe ..
I believe that can be done within your budget constraints...I'm assuming some of that money will be used to bullet proof the 700R4...
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
This will give you a good idea of what all the crate motors can do.
JIM
http://www.hotrod.com/how-to/engine/...-engine-tests/
JIM
LastBigBlock (02-04-2016)
How about I PM you a picture of the Houston Texans cheerleaders holding a bottle of Balcones Single Malt Whiskey and a plate of smoked brisket while sitting on top of a pile of guns that were just imported from a liberal state that confiscated them and donated them to the good people of Houston?
How about you pm me that pic instead!
With the motors you are looking at the only way to even hope for a 10 anything is with NOS
A zz383 450/450 would on a good day with a good launch be around 12.4
Here use this calculator it is pretty cool and is good tool to help form ideas for power levels you might need to get 1/4 mile times you are hoping to hit .
https://robrobinette.com/et.htm
You check out the calculator towards your et? There are a lot of variables that could change the et but not add or take away power, such as gears, stall ect. http://www.wallaceracing.com/hpcalculatorquarter.php this one I like and I really only use the Mile per hour as it's usually constant unless you change something to make more power. They use 10% loss between crank and rear wheel, but as you know, the losses any were between 20% - 30%. What did you vette dyno at the rear wheel?
Last edited by bluedawg; 02-04-2016 at 11:42 AM. Reason: Damn Eskimo's set fire to my igloo..
You can't make blanket statements. Your above statement is only true for a low power motor that is done in the low 5000 rpm range.
I did a lot of research with gear ratio calculators and i determined that the best ratio was 4.11 with a 700R4. 4.11 even sucks with a 700r4 because second gear I did not shift into 3rd till I was going over 90 mph and red line in 3rd was about 150 mph with my 28 inch goodyear slicks. So I was nowhere near rend line going through the traps.
My Vette was a consistent winner in bracket racing at 11.70's with my 383.
IMO 383's are was of time and money. When for the same amount of money you can use a 3.875 crank and have a @396 ci or a 415 ci using a 400 block. when I was doing 11:70's at the annual all corvette drags the around 400 ci vettes were doing 11.40's.
http://www.hotrodworks.net/hotrodmath/quarter.html
