Found my EZ-EFI 2.0 problem...
When she runs good... omg... she runs like a bat out of hell.... BUT,,, when the EFI starts going south she runs like a scrap yard vega...
As many are aware that have the EZEFI they are highly susceptible to RFI.....
Well... seems i have a small head leak under the 4 and 6 exhaust, this leek will squirt water/antifreeze on the #4 and #6 plug... this is enough to cause the spark to misfire sometimes and thus cause error readings and misfires via the computer...
So... got to take the head off this weekend.. ugh....
gdh (02-11-2016)
Glad that you finally tracked the issue down Paul. What a 'ell of an ordeal you have been through. Thank-you for always being so forthcoming and honest in describing your issues with the install. I am sure that many of us have book marked your threads.
Good news/ bad news. Always good to find the problem and get it solved but requiring work. I'm hoping once the weather gets a little warmer I can get mine out for a few miles. Supposed to be wind chills in the -20 degree range. Not the best driving conditions for a topless roadster.
How did you find that leak ? Did you pressure test the cooling system ?
water/antifreeze residue all over the plug wire/cap, and the sweet smell of antifreeze ... ... taking the head off this weekend:-(
I am glad I got away from Fast , Holley has it down as far as the wiring and computers.
Get a whole stack of .1 mfd caps at about 50 volt rating, and bypass every input to ground at the computer with them, if a two conductor wire say for water and air temp....go across the two wires at the computer.....TPS take the output/middle terminal to ground with the cap, bypass the computer power input with a 100 mfd AND a .1 mfd cap also in parallel, IF it is indeed EMI you maybe want to put the computer into an aluminum box that is mounted to body metal, obviously use care on the wiring/mounting.....EMI is not your issue, bet odds, it's RFI sparks from the ignition system,
sounds like **** poor engineering to me......
[QUOTE=mrvette;1591546748]
I think he means RFI ,, But you are spot on as to the issue but the problem is not the computer it is the wires leading to it that carry the interference to it .
Problems came from the water hitting the #4 and #6 wires at the plug boot
Well... not exactly what I thought... lol :-)
So... Went to go fix the problem... had everything off,,,, Exhaust, intake, FI, water drained, distributor... everything...the next step was the head bolts... But I stopped, and thought I would take one more close examination.. Why? the back side of the headers were clean?!?!!? like WTF?!?!?! .... So, I take another very close look at what appeared to be a leak between the head gasket near the freezpluf behind the #4 and #6 exhaust ports... Still looked like a head gasket leak.. but since no spray was on the back of the headers I knew this could not be the problem....
Started to clean and examen EVERYTHING!!! took out the magnifying classes.. looked at water spots, which way they were splattering and falling... doing everything I could think of to track down the water problem....
After much looking I felt positive it was the hoses by the heater control valve were bad or loose... i determined this by looking at the inside if the hose to see sings of water exiting the clamp area,,, but after more testing and deliberation, I ruled that out... must be the valve itself leeking!! so i pressurized the unit under water... no leek..
FUDGE!!
then i noticed a small hole in the water puck bucket... a hole (as seen below) and this was the root of my problems...
The overfill tank... and now it all makes since...
I could take her out and drive 200 miles without a hiccup... park her for a little bit... drive some more, and all goes to poo...
What would happen, is that when parked and engine turned off, the temp would rise enough to pressure water out of the radiator into the tank, as it is supposed to) when this happened, because where the hole it, it would squirt to... and this hole was hidden behind the 2 heater hoses, thus you could not see it...
FUDGE!!
Good find. I've found never jump to a almost fitting solution when it come to an EFI problem. ALL of the symptoms have to fit or you have not found the real problem.
How is it you never noticed a puddle on the floor ? That tank should always have coolant in it , always not only after a long drive but on every drive.. ? ? ? ? ?
bright side is... didn't have to take the head off and order and wait for the correct head gasket!!
never checked the tank, as I always check the radiator, and it is usual 1/2 inch from the top... I top it off, squirts on the plug wire,,,,,
Well.... When it rains.... it pours:-)
That was 50% of the water problem.... the EZEFI 2.0 is HIGHLY SUSCEPTIBLE TO WATER...
The leak mentioned above would spray on the plug wires and caps making a lot of EFI that plays havoc on the EFI computer...
The other... found a few days ago, ... was a bad radiator cap.. it would leek or spray a fine mist, this mist would collect onto the CAI underneath and follow that back to near the thermostat housing, then dripping and puddling near it... then the turbulence under the hood would then mist it pint to MAF sensor under the front bowl of the EFI... then make it run like poo....
fixed.... so far... 100% good:-)
