excess header heat on 69 big block at floorboards
This is under my floorboards just at the header to exhaust connection. It appears to be factory based on location of bolts but seems to be made of plastic. Seems strange to use plastic as heat protection?? Anyway, it is getting burned by the headers which I do plan on removing at some stage. However, in the mean time, does anyone else have this problem and does an aftermarket solution exist. I assume I will have to fabricate some type of metal heat protection. Also,when I do get around to putting factory manifolds back on, does anyone know where I can get this plastic looking part? I don't see any of the suppliers listing it.
Thanks, Pete
Received 1,468 Likes
Cruise-In II Veteran
Looks like I have the wrong headers for the car as mine are not situated where yours are but rather closer to the door. They do sit way way to low so looks like they are one of the next things to go.
Is that a big block car you have in the picture?? I am surprised a set of non corvette big block headers would actually fit into the car being how little wiggle room there us under the hood.
Again, thanks so much guys, a picture is so often worth a thousand words.
Pete
Seems to me that you get two options - headers that hang too low, create ground clearance issues but don't 'cook' the floorpan and your feet (i.e Hookers) ~ or ~ headers that 'cook' the floorpan and your feet but have reasonable ground clearance (perhaps Hedman)
