Leaking speedo gear housing
I noticed a leaking coming from the speedo cable on my tci transmission the other day on my 79. So I removed the cable and bought a new housing and gear. The day after I replaced it. Still leaking. So I decided to just buy a TCI one and gear from Jegs. Installed it today. Went for drive and notice still a small leak. Is there any real tricks. Seems like it is the internal seals that are leaking.
Thanks Joey
Thanks Joey
There is an 'inner' O-ring and an 'outer' O-ring on that speedo gear housing. You should put some Vasoline or trans oil on the rings before installing them, otherwise they can get rolled or cut during installation.
