ZZ6 Swap
It will fit like a glove , all items you have should transfer right over to it ..
Ok great. I know about the water pump, Hei, etc.. I was however concerned about fitting my hooker headers/sidepipes to the exhaust ports, since they are D shaped on the engine. Should I be concerned with that..?
Run the gasket that fits the header you should be ok I ran non d-port headers on the fast burn heads and it worked well
