`69 windshield wiper circuit
Old 03-14-2016, 01:57 PM
bjerdin
Cruising
bjerdin's Avatar
Default `69 windshield wiper circuit
I find that the wiper door limit circuit only gets power (12ga R/W) when override switch is on what am I missing
Old 03-14-2016, 02:13 PM
65GGvert
65GGvert's Avatar
Received 3,217 Likes on 2,301 Posts
That's the way it works. The override switch isn't to make them work, it's to stop them when you need to do maintenance on the blades. So you should only have 12v when it's on, and zero coming out of the switch going up to the limit switch when it's off. The override switch should be on all the time UNLESS you want to stop the wipers mid-swipe.
bjerdin (03-14-2016)
Old 03-14-2016, 07:08 PM
bjerdin
Cruising
bjerdin's Avatar
Default Override circuit
Now that I`ve got my head wrapped around it as a disconnect I`m ok.
thx/bj
Old 03-15-2016, 10:02 AM
Grahamred70
Grahamred70's Avatar
The normal wiper switching is done on the ground side, the supply is hot all the time.
Graham
Old 03-15-2016, 10:35 AM
65GGvert
65GGvert's Avatar
Graham
Unless the service override under the dash is turned off, which is what he was doing. That disconnects the 12v that passes through the wiper door limit switch then to the wiper motor.
To `69 windshield wiper circuit
Quick Reply: `69 windshield wiper circuit
