Mandrell bent upper radiator hose
Old 03-30-2016, 10:28 PM
spedaleden
spedaleden's Avatar
Default Mandrell bent upper radiator hose
Anyone know where I can get a custom made upper radiator hose made out of aluminum or stainless. Chicago area
Old 03-30-2016, 11:28 PM
babbah
Support Corvetteforum!
babbah's Avatar
Summit racing sells the ones that you can bend yourself.
Old 03-30-2016, 11:29 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
On my C4 racecar I bought aluminum tube from McMaster Carr and just used rubber elbows and couplers.
Old 04-01-2016, 10:17 AM
Gale Banks 80'
Gale Banks 80''s Avatar
Anybody with a Mandrel Tube bender could make it. Only problem is there are not that many around. If there is a specialty Exhaust shop in your area they might or could know who has one in your area. You can also buy Mandrel U Bends and cut and weld them into the shape you need.
Old 04-01-2016, 11:02 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Getting that little lip on the end of it will help ensure its leak free not sure if you really have to do that or not or how it would be done
Old 04-01-2016, 06:01 PM
AzMotorhead
AzMotorhead's Avatar
The raised rib at the ends is made by a tubing beader
Old 04-01-2016, 10:28 PM
Kubs
Kubs's Avatar
This is the proper way to do it. I just crimped mine with ignition pliers.
Old 04-02-2016, 08:55 PM
croaker
croaker's Avatar
Summit has flexable hoses and some bends made of of some kinda silicone stuff. 24" hose about 40 bucks in colors. Prolly be my next replacement hose as the last couple I bought were a little short and cheap looking.
Old 04-03-2016, 08:47 AM
redvetracr
redvetracr's Avatar
you could try Boyce Engineering in Melrose Park, Bob Boyce is an old stock car guy who still (on occasion) races a Cheetah at Road America.
To Mandrell bent upper radiator hose
Quick Reply: Mandrell bent upper radiator hose
