C3 Power Window Article on CCTech!
Platinum Supporting Vendor
http://tech.corvettecentral.com/2016...ic-windows-c3/
Check out the latest article on CCTech, covering C3 power window conversion.
Received 1,246 Likes
You left out a few important details.
You must install the motor before you remove the nut and bolt.
The motor holds the regulator in place, if you take the bolt out first the regulator will unwind and could hurt you!
You will have to collapse the regulator to get it top fit into the bottom of the door.
There are two terminals on the motor, both get 12 volts positive.
One terminal is for UP and the other for down.
Apply 12 volts to only one terminal and GROUND the motor case.
Order new door panels.
