'72 454 fuel pimp change?
I'm fairly sure I have crud in my original fuel tank. Has all the symptoms of fuel starvation. Not getting steady fuel flow to the carb.I would like to go ahead and install the new fuel pump and correct formed steel pump to carb line. The line now on was bubba bent and does have some crimps/dents where there should be none. Waiting for the back ordered new tank to arrive. Sending unit,new rubber fuel hoses and over fill and pick up sock as well to arrive. Would I damage the new fuel pump or should I wait on the tank and do both jobs at the same time? Car is now up on jack stands as I put in new correct transmission lines yesterday. The front wheel is off and access is great for the fuel pump swap
I'd install it all at once, for obvious reasons.
The new fuel pump won't be damaged by a little crud and it might be your problem. You can use a clear fuel filter to see how much junk is getting pumped thru. You could be getting a blockage at the tank but that takes a lot.
croaker (05-11-2016)
1. Pump is cheap, just do it
2. Need a knuckle joint for your socket wrench
3. Push rod will fall down, use a bent hacksaw blade to hold rod in place while you install new pump.
Good luck
Pete
Just went through this 2 weeks ago in my big block with headers, (read very little room) Took 3-4 hours and I have no knowledge at all in this area. My words of advice,
Good luck
Pete
Good luck
Pete
Good luck
Pete
Good luck
Pete
