swapping orig. distributer with street fire HEI
7th Gear
I just bought A 1969 L46 convertible and would like to change out points system for HEI. i purchased An MSD street fire PN8362. Here is a little info that may help you help me . my car has the orig. points distributor and external coil. but they have put hooker headers on. currently the wires are under the headers .should i go over the valve covers with wires? and not sure on which plugs to use. Any pointers/pics before I start this would be AWESOME. Thank you, Jerry
You are not going to gain any performance by changing. As a matter of fact, the point type system is less likely to fail than the HEI, both electronically and mechanically-especially the tach drive gears. Remove and inspect/rebuild the original distributor, it is good for 6000 RPM.
All the msd streetfires are made in china and the ignition modules are troublesome in many cases. I agree, keep your stock distributor and have it rebuilt/recurved and retain the stock look a 69 should have. If you insist on an electronic unit have a conversion kit installed.
BTW, HEI is way better than points. No maintenance, no adjustments, not limited by RPM. Peterbuilt is right about warning you that you will lose the use of tach in your car, you'll have to switch to an electronic tach.
