th700 or th200
th700 or th200
Hi all
What is better on an 78 with th350/3.08, th700 or th200 ?
What modification in relation at the th350 whit th700 or th200 ?
Thanks in advance for yours responses
Re: th700 or th200 (French78)
the 200 might be better choice for you for more of direct change over,if you got a 350 already in it...check with jvette73 he has a 200 in his.
Re: th700 or th200 (pats406nitrovette)
From a gear perspective, the 700 has a more aggressive 1st gear, which may work better with your 3.08s. The 200 would save you the cost of a cross member and driveshaft shortening though.
Go with TH200-4R. This is the better choice IMO.
TH700R4 has a big shift drop from 1st to 2nd gear.
TH200-4R doesn´t.
TH200-4R is easier to install.
I plan on buying one in a few years when my race engine will be completed.
Check this site: http://www.442.com/oldsfaq/oftrn.htm
and have a look at our latest thread about this
http://forums.corvetteforum.com/zerothread?id=343410
:seeya Markus
TH200-4R doesn´t.
:seeya Markus
