Transmission issues - Need reassurance.
#101
St. Jude Donor '11-'12-'13,'19-'20
OK...so car not skipping, but the rpms seem really high. At 63 mph the rpms are around 3100-3200. My friend who just installed the rebuilt trans is still concerned the rearend got switched out. Thinks it is geared way too low. I drove the vette to Florida twice and I don't remember it running that high. There's no Overdrive, but still. Am I just imagining a high rpm? Does this seem right?
Kim Moulton Miller (05-24-2016)
#102
To find the rear end ratio, you need to jack up the car, turn the drive shaft ONE turn, and count the number of revolutions the rear tire makes. This will get you pretty close depending on how accurately you measure.
'Switching the rear end out' is no small feat either.
#103
Received 3,043 Likes
St. Jude Donor '05
Do you remember what it read before?
Wonder if they switched out the speedo gear in the trans w/o thinking about it by mistake-
Take reading at a lower speed see what it does post up
on the pic most are too shy or its some dude posting with a chicks name hoping to get help quicker.
Or a pic of a fat guy in a Hawaiian shirt lol
#105
Wonder if they switched out the speedo gear in the trans w/o thinking about it my mistake-
As for the pic...thanks! I'm sure you can tell by my ignorance to cars that I'm all girl! lol
#106
St. Jude Donor '05
curious to hear if its in 3rd or something else
Turn around
Edit: can you feel it shift into 3rd or if you put it in low manually can you work your way up to 3 and feel it/hear the rpm change
Turn around
#107
Your 78 should have come with like a 3.08 gear or even 2.73, which would make the rpm at 65mph closer to ~2500, or lower. 3.70 was a popular performance upgrade. (LOL I did it). Jacking it up and couting the turns as suggested is the quickest way to tell.
#109
#111
The 5th character should be an L or an H.
In any case there apparently were optional rear diffs that year.
According to this:
http://www.corvsport.com/Corvette/C3..._1978_VIN.html
The code is on the rear diff itself.
According to this:
Optional Rear Axle Ratios (G95) - A selection of optional rear axle ratios.
In 1978, these included: 3.08 (Code OA), 3.36 (Code OK), 3.36 (Code OM), 3.55 (Code OH), and 3.70 (Code OJ)
#112
Dementer sole survivor
Received 6,292 Likes
2016 C3 of Year Finalist
I agree. Find a flashing radar speed sign nearby and see what the sign says when your car says 60. I bet they have the wrong speedo gear in the tranny
Kim Moulton Miller (05-25-2016)
#113
St. Jude Donor '05
Hmm how bout GPS app on phone
#114
Ok fine. Mr smartphone uses common sense.
I actually have a speedometer app and didnt even think of it.
#116
#117
[QUOTE=REELAV8R;1592282656]The 5th character should be an L or an H.
The Corvette Black Book says the 5th character should be an L (350ci, 176, 185 hp) or a 4 (350ci, 220hp, L-82) which mine has so, with the 4 in her VIN, her car is an L-82.
#118
OK guys! I have my baby home!! Just drove her about two hours, mostly Interstate and she ran GREAT!! 59 mph = 2900 rpms (checked speed against speedometer app and it is accurate) I felt all the shifts and convinced tranny is working right. The only issue was I heard a knocking, so I stopped in Advanced Auto to check it out (and to buy replacement rearview mirror and air filter - which for some reason there wasn't one in there after the rebuild! ACK!!) The knocking is the power steering pulley. I replaced that pump about 7 or 8 years ago. Guess it's time to do it again. And the A/C still needs to be replaced - AGAIN, but still waiting on NAPA to tell me if they will honor the parts or not. A guy from on here hooked me up with a Corvette shop not far from me. I spoke with him yesterday and I will be going to see him soon as I can to get his opinion on things in person. For now, I'm going to take it easy with "her" and enjoy early morning cruises until I get the A/C fixed. After all the mechanical "stuff" fixed, I will begin on the interior carpet, weather stripping, passenger side mirror guts, and paint job! I'm just happy to have her home! Thank you to everyone for your help!!!!! Kim
Taking my baby home! 5/26/16
#119
St. Jude Donor '05
Looks like a happy camper there
Least its back on the road, nice color too!
